02 sensor help and yes i searched
Old 04-11-2011, 12:53 PM
ADHDmax's Avatar
ok so i just failed emisions for the second time after changing the 02 sensor first it was p0138 and now its p0141 an the sensor was brand new. The mechanic down at the shop kept telling me that my car was cali spec just cause the hoo i have on my car says that it passes cali and us regulations but the hood isnt off my car. is there a way to tell other than by just the cats on my car or no im confused about all that and do u think maybe i coul have just gotten a bad sensor from advance auto? thanks
ADHDmax is offline
Old 04-11-2011, 01:12 PM
Shift_Nismo's Avatar
Idk how he could tell by looking at the hood, as I dont think the hood has any identifiers on it, but if you look on the passenger side firewall (in the engine bay), there is a metal plate with numbers and letters on it. The top row is the VIN number, the second row is model info. The first five characters of the 2nd row are BLHUL. The 12th character is the destination:
N = Canada
V = California (Cali spec)
U = US, (fed spec)
Info like this can be found in the FAQ section: http://forums.maxima.org/707273-post4.html
Shift_Nismo is offline
Old 04-11-2011, 01:26 PM
ADHDmax's Avatar
ok i did that and it says that im a cali spec but i only have the 2 connectors in the front and i was told cali spec has the four connectors there under the hood in the front i mean
ADHDmax is offline
Old 04-11-2011, 01:32 PM
Kevlo for President
Kevlo911's Avatar
Only 99 cali spec had more o2 sensors.
Kevlo911 is offline
Old 04-11-2011, 01:54 PM
If I remember correctly, 3 of the O2 sensor connectors on a CA spec Max are up front, with 1 on the back left by cylinder #1.
The Wizard is offline
Old 04-11-2011, 03:34 PM
ADHDmax's Avatar
ok thanks guys i went to advance and they said they would exchange the one i have for free thinking maybe i just got a ba part gonna try that will let u know what happens any more helpful advice would be welcome
ADHDmax is offline
Old 04-11-2011, 04:41 PM
mmgio's Avatar
I have a 98 cali spec and the o2 sensors are the same as a fed spec. 99's have o2's in the y-pipe I believe which may be different.
mmgio is offline
Old 04-14-2011, 05:35 PM
ADHDmax's Avatar
another question is the heater circuit code only caused by the sennsor itself or could it another problem
ADHDmax is offline
Old 04-14-2011, 06:04 PM
asand1's Avatar
Could be the fuse or wiring harness.
asand1 is offline
Old 04-14-2011, 07:00 PM
ADHDmax's Avatar
ok gonna sound like a stupid question how should i go about checking the harness out
ADHDmax is offline
Old 04-15-2011, 09:04 AM
bobflood's Avatar
Turn on cold engine, unplug sensor. see if you have 12V on the pins for the heater circuit. If not, and fuse is OK, there is some problem with the wiring.
bobflood is offline
AaronL
08-08-2020 10:31 AM
06-06-2017 02:01 PM
hayne
10-05-2015 11:53 AM
HerpDerp1919
09-29-2015 02:02 PM
ac max 92
09-17-2015 07:35 AM
Quick Reply: 02 sensor help and yes i searched
