Valve Cover Gasket Replacement...
#41
But if you haven't ever done anything like this before, find a friend who has to give you a hand. The upper intake removal is a rather involved and difficult process for a newb.
#43
OP or anyone else who has done this, few questions....
1- Do they sell, like a vacuum hose line kit for this car? I think I have a few hoses cracked or splitting, but I dont know what sizes to get....
2- do you have to drain the coolant since you're dealing with coolant lines?
3- Also, when installing ANY of the gaskets, do you apply RTV on the whole gasket or just the corners? Like a small bead all along the gasket and a mound at the edges?
Im planning on doing this within the next month, any help is much appreciated....
#45
2. No. Very little will spill when disconnecting the coolant line at the back of the UIM.
3. The FSM calls for just the corners.
#47
ok great, good info man.... Thanks....
#48
Thanks....
#50
Page EM-10 will give you the simple details on removing the LIM.
#51
/\ True, but you forgot the most crucial part. Be extremely careful with the various fuel injector o-rings, note how everything goes, and don't drop them into the LIM. Tape off the LIM to ensure nothing falls down into the engine.
#52
Valve Cover Gaskets - for my 3rd DSC4
Background
This is my third DSC4 to get a VC gasket job. I have replaced the VC gaskets on the first two DSC4s with mixed success. The first DSC4 VC replacement job was a success. Unfortunately, the 2nd job is now seeping again after about 8,000 miles. Me and my family like to drive DSC4 5-speeds -- so VC gasket replacement goes with the territory.
Hopefully the third time (and 4th) times will be a success. I would like to post a guide from this operation that may be useful for posting in the "how to" section.
Today I have questions for the group before I start down this road again and hopefully some coaching by other members will be greatly appreciated.
Vehicle
1999 Maxima SE 5-speed
Gasket Set
I've been using the Felpro gasket set that is sold by Advance Auto -- part number VS 50494 R that sells for $52.99. I usually get a nice discount at Advance but if I need to using a different brand of gasket it will be worth it to keep from having to do the job over again.
RTV - Permatex Ultra Gray was used in the corners near the timing chain and a small bead was run along the head surface to provide extra protection -- per some forum recommendations.
Bolt Sequence
The recommended torque up sequence from the FSM was used.
Questions
1) Have other members had success or failure with the Felpro gasket set from Advance?
2) Is Permatex Ultra Gray recommended as the RTV sealant?
3) Should RTV be applied on head gasket surface in addition to the corners that require it in the FSM?
4) Any tips from members that have experienced failure on this job?
Plenum Removal
As this point I have figured out a routine and tools for making plenum removal and installation go as quickly as possible. I can make pictures of this job and post a write up for all to enjoy once it is done.
Please post any suggestions and interest in having a "how to" write up available to share any tips for success on the VA replacement job.
CS_AR
Vehicle
Gasket Set
Bolt Sequence
Questions
Plenum Removal
CS_AR
TKHanson
11-24-2018 01:39 AM
knight_yyz
11-01-2015 01:34 PM
tseng1023
10-15-2015 08:30 AM
