AC comprassor not starting
hi guys
summer is comming . the wethar becomes hot . so I started the AC and I surprised with hot air . I notes that the comprassor did not start becouse I did not hear it's sound .
any thing to fix this problem ?
make sure you drain and fill it with the coolant and the lubricating OIL from nissan.
ALSO there is a trigger switch on the compressor (black connector with black single wire). Ensure that is still there and in tact.
Probably a leak, Dead Compressor, or compressor clutch is not engaging(could be many other things too). But be careful refilling R-134a from the "can" can be dangerous/explosive, also there is really no way to meter how much refrigerant is in your a/c system already or how much you're putting in.
Honestly I would get a/c work done professionally. But if you insist on doing it yourself wear eye protection because getting that stuff in your eye will most likely freeze it and when u blink it will shatter.
Oh and DO NOT USE THAT STOP LEAK **** OR ANYTHING THAT CLAIMS TO STOP LEAKS, it will plug the leak and any other orifice in your a/c system.
97_GXE
09-15-2015 06:47 AM
QueensMAX
09-15-2015 04:14 AM
trungg86
09-04-2015 04:58 AM
