4th Gen LED Dome, Map, Licence, Trunk Conversion Write Up
Hey Guys, I've decided to do another maxima write up, I'm looking for someone in either the Toronto or Ottawa areas (in Ontario of course) to do a COMPLETELY FREE LED conversion (installation included) on a 4th gen Maxima.
Whats the catch you ask?? I need to take pictures of your car and the install for a complete write up, so I basically need to borrow your car for an hour or two (you can do all the driving, I don't really care).
Looking to get this done sometime this week and then I'll update the thread with pics and instructions just like I did with my 5th gen.
Post here or PM me if you're interested! =]
EDIT: 6 months later I finally got my hands on a pearl white 1996 Maxima!
For those concerned, I had no BCM (Body Control Module) issues whatsoever, I think that failed BCMs are due to improper installation and failure to follow basic precautions.
The Results:
Scroll down to posts #16-18 for the complete writeup!
The Results:
I don't understand why do you want to do it - what's in it for you?
And besides why not doing it on the newer versions - 6th or 7th, rather than our version. I have 96 I30 and am pretty happy to just keep it going, rather than doing any dress up modifications on it.
I live in Ottawa by the way.
I will be also looking for a 6th or 7th gen in the near future, I'm trying to take this one step at a time though.
PM me with your number if you're actually interested.
I've got a bunch of opinions regarding lighting upgrades in older cars, and they're pretty consistently against it. LEDs in older Maximae usually don't look good. The spread and diffusion in the lamp itself just aren't very good because the housing was designed for incandescent bulbs, not LEDs. The same reasons that prevent LEDs from being effective upgrades to incandescents and CFLs in household lighting applications apply to automotive lighting - if the fixture wasn't designed for LEDs, they don't tend to produce good results.
Again, that's my opinion and you may find some way to make LEDs look good, but show me an LED-retro'd dashboard from the '90s that isn't spotty and inconsistently lit and I'll do mine up in a jiffy. I'm not seeing a trip to Radio Shack in my future.
When I post pictures of the install you can decide for yourself if you like them or not.
Now that you mention...uh, the subject of the thread, I've seen a pretty decent installation in dome lights somewhere on this forum. I was using dashboard lights as an example of why I don't think LED conversions end up looking good.
That said, I'm not sure why I posted that in this thread, as it's kind of just not really cool to jump in and **** all over someone's offer. So I'm just gonna go ahead and remove it.
I just did some reading on this thread, which was bumped today: http://forums.maxima.org/4th-generat...t-working.html, which shows electrical issues on 4th gens after doing the LED upgrade.
So I am thinking I will pass. Again my first priority at this point is to keep the car running and fixing it myself, rather than doing modifications to it.
Hey guys I just wanted to chime in here since I've done the LED swap-out in my 4th gen (edit: my year is 1999).
I purchased the LED's from Tyutyunnik and they came in a nicely padded envelope with everything wired up correctly (all connectors pre-fastened to the correct respective LED panel). Moreover, the install was a breeze. For my car (since I have the one with sunroof, or maybe since it's Infiniti - not 100% sure), the front map light is only 1 bulb which I replaced with a 2x3 panel. In the doors as well as the dome light I put in the 3x3 panel. I put one T10 bulb in the trunk light, and I haven't gotten around to doing the license plate lights yet. They all work great; yes, the lights aren't diffused properly because the enclosures were made for traditional bulbs, but the light output is much better and they are exactly what I wanted. I will post pictures when I have a chance, but I've been way too busy as of late to borrow a camera from a friend to take pictures. No BCM problems/etc whatever other electronic glitches yet after over ~1 month of driving.
Lastly, Alex (Tyutyunnik) has been very helpful with the LED's, checking with me if I had received my order and how the install went, if perhaps the T10 bulbs had gave me problems, etc. His initial 5th gen LED writeup was what prompted me to do the upgrade for my 4th gen; whoever is local to him should definitely take him up on the offer, it is a steal.
Thanks Michael, I'm glad to hear they're working well. What year is your I30?
You guys are starting to scare me though with this BCM horror story, I definitely don't wanna be responsible for screwing up someones electrical system just for some led lights.
How many of you with 4th gens have successfully done this mod with no issues?
Does Alex Tyutyunnik have a website? How did you get the lights from him? I purchased some "replacement" LEDs on ebay and it is about 50/50 what you get there. The bulbs are all in working order but the 1156 for the bumper lights will not turn on nor will the map light. I have read that the resistance (or lack of) in the LEDs makes the car think that the regular bulb is burnt and it will not operate. I did not have any problems with the door lights, side markers in bumper, reverse lights, trunk light or license plate lights other than not being as bright as I would have liked. I am waiting on the dome light now.
Anyway, I have plans to run the bumper lights as DRLs (I rewired these lights with the corner lights so the corners are now the blinkers and the bumper lights are now parking lights) with the LEDs installed but I am tired of having to turn on all the other lights and my clock dims. The stumbling block is that I want to use a Cruise Control switch I got at the wrecking yard as the DRL on/off switch but cannot figure out the wiring. I also have the under hood cruise relay. I have searched the forums but no one has repurposed the cruise switch to this point. There is a blank spot next to the dash dimmer to the right of the steering wheel above the key that this switch fits perfectly into. I think it will be very cool once I get it figured out.
Any help, ideas?
Any help, ideas?
Starting off at the front map light. Car is equipped with a sunroof so there’s only one in the middle but the non-sunroof models may have 2, can someone confirm this?
Cover pops off to reveal a small bayonet bulb.
Replaced with a bayonet adapter.
Bulb goes inside. A 9SMD board should do just fine.
Test on.
Cover goes back on.
Moving onto the doors, stock bulb.
Cover simply pops off like usual, revealing a small 194 bulb.
Replaced with a T10 adapter for our upgrade.
Another 9SMD board goes into the door.
Cover goes back on, looks much better. Repeat for other door.
Test on.
Cover goes back on.
Moving onto the middle dome light. Stock yellowish light.
Cover pops off as usual, a small festoon bulb is just asking for an upgrade.
Dual bulb festoon adapter in place.
Two 9SMD boards should do the trick.
Cover goes back on. A major improvement.
Moving onto the rear of the vehicle, almost thought that Nissan forgot these bulbs but they’re hidden in the bumper, looks like they’ve never even been touched. Remove 2 screws and one clip in the middle to get to the bracket.
Some heavy rust left me unable to open up the housing so I could access and replace the bulb. Not to mention the bracket looked like it was about to disintegrate. Time to replace the whole thing.
Nisan wanted $68 for a new bracket…yeah right. I decided to go ahead and make my own using a piece of wood lying around and two lights I bought from a local parts store for $5 each.
The finished product
Securely mounted using the stock holes, looks pretty close to stock if you ask me.
Onto the trunk light, stock.
Pops open with your hands. Reveals a small 194 bulb.
Replaced with a 5SMD T10 bulb.
Cover goes back on.
And that’s pretty much it! Most of my time was spent making the custom bracket to replace the rusted one, otherwise everything else went smooth, no BCM issues at all.
Comments/Questions welcome.
Cover goes back on.
In my case, I have two types of bayonet adapters whose polarities are reversed, when the first one didn't work I just used the second one and voila. It really depends on the car and the type of bulbs you're using but its always good to be prepared.
Good question, I wouldn't exactly call it "reverse polarity" but it definitely can give you trouble with LEDs depending on which kind you get.
N>>>>>P
P>>>>>N
Have encountered this on a number 4th gens when using SMD boards
EDIT: also, where did you get those license plate lights at?
They should be available at any sort of auto parts store though, they seem to be very generic lights.
http://www.superbrightleds.com/cgi-b...urn.html%23lpc
The LPC-x-W2 lights are the same size as the stock ones, mine came in the mail today but I need to grab a new bracket for the lights.
Bracket-
http://forums.maxima.org/4th-generat...t-bracket.html
Bracket-
Bracket-
Bracket-
jds22
09-04-2015 01:52 PM
