Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 03-07-2011, 03:29 PM   #1
Points: 6,394, Level: 52
Points: 6,394, Level: 52 Points: 6,394, Level: 52 Points: 6,394, Level: 52
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
P0100 STALLING BUCKING PROBLEM FIXED!
About 5 months ago just before I tore the intake down to replace the very leaky right bank rocker cover gasket she started stalling when idling, then bucking at higher rpm's. Progressively becoming more frequent and then finally...got P0100 MAF code. After suspecting a poor ground, broken connection in the wiring harness and having a P0130 (right bank o2 sensor-firewall side) popping up during this ordeal and reading tons of post about this on this site and others I finally found the definitive cause. On the MAF the 3 pin connector is soldered internally directly to pins coming off the circuit board-creating an electrical as well as a mechanical connection. Not a good design! When I took the MAF apart the pins looked connected but were cold solder connections at this point. I modified the connections with short wire leads resoldered and flipping the harness connector around - the engine is back to running rock solid! I suspect this is THE reason most 4 gen max's and I30's are exhibiting these symptoms and many have paid hundreds and/or thousands having mechanics chase down the cause. Hope this helps others.
__________________
97 Super Black Max...
maxirob is offline   Reply With Quote
Old 03-08-2011, 05:26 PM   #2
Points: 276, Level: 5
Points: 276, Level: 5 Points: 276, Level: 5 Points: 276, Level: 5
Activity: 0%
i too have a p0100 code and i tested the MAF and it was fine, did resistance test, backprobe voltage check, cleaned with MAF cleaner, cleaned throttle body, and everytime i reset ecu the code came back. finally bought a new ebay MAF and it seems to have fixed the bucking problem but the engine still doesn't run perfect and the p0100 code still shows up.
did you try backprobing your MAF and did it read correct values?
i also replaced all vacuum lines going into the maf area and I am now waiting on new air intake hoses to completely replace everything before the throttle body including a different aftermarket air filter (had stillen)
mtnbikeskiparty is offline   Reply With Quote
Old 03-08-2011, 05:27 PM   #3
Activity: 0%
I'm not quite sure what you are saying you did to the wiring connector? did you get rid of it and just solder the wires directly together at the MAF?
Old 03-09-2011, 06:52 AM   #4
Points: 8,298, Level: 61
Points: 8,298, Level: 61 Points: 8,298, Level: 61 Points: 8,298, Level: 61
Activity: 4.8%
Activity: 4.8% Activity: 4.8% Activity: 4.8%
He is saying (i think), the MAF has 3 pins on it that connect to the car harness. When he took the MAF apart, he noticed the 3 pins are soldered directly to the MAF circuit board. He used wire and resoldered those connections. and that seemed to solve his problem.
those ebay MAFs are usually hit or miss and not OEM. Autozone has reman MAF where another company resoldered OEM MAFs.
HIt the JU for a used MAF or AZ. I wd be leary with ebay MAFs. Or check the classifieds...someone always selling used MAF.
cashoit is offline   Reply With Quote
Old 03-09-2011, 08:31 AM   #5
Points: 6,222, Level: 51
Points: 6,222, Level: 51 Points: 6,222, Level: 51 Points: 6,222, Level: 51
Activity: 0%
Click the image to open in full size.
i had to resolder these cicled points and it solved my issue but make sure U RESEAL THE MAF i did not and condensation got in and it made the car feel like i was misfiring i had another maf laying around put it in and solved that issue also could have saved the trouble by RESEALING THE MAF with some silicon hope this pic helps
if you in the market for a used maf check out fallenones thread in the 4h gen classifed dudes got alot for sale
__________________
luke95gxe is offline   Reply With Quote
Old 03-09-2011, 03:33 PM   #6
Activity: 0%
Excellent Pic luke95gxe. I tried to take pictures of what I did but they turned out lousy. I unscrewed the wiring harness connector, soldered short lengths of insulated wire on and then flipped it 180 to get them out of the way, and then soldered to the pins coming off the PC board. The idea was to de-couple the mechanical connection. Let me tell you I cleaned, and cleaned, and checked vac lines, and everthing. What kept throwing me was I reached around and moved the wiring harness and thought that was the problem, the thing was I was moving the wedge shaped box in the processes and putting just the right angle of movement on the MAF housing to trigger the MAF's internal cold solder joint and kill the engine. It's been a week since I repaired it and it's still rock solid. And YES you must remove all the old silicone and reseal with new RTV.
__________________
Old 03-09-2011, 03:39 PM   #7
Activity: 0%
Quote:
thanks man i chased this problem for a long time it got real bad in the summer with the heat and all
__________________
Old 03-09-2011, 07:50 PM   #8
Activity: 0%
One more thing I discovered relatiing to resealing the cover back with silicone so its air tight. I noticed that after I removed the MAF assembly from the car I could press on the circuit board cover and hear air whistling in/out of the plenum. I discovered there is a tiny vent hole above and just off center on the TB side of the sensor vane going into the circuit board area, so I figured the circuit board enclosure HAD to be sealed or air could leak in and throw the sensor reading off. I even put a thin bead of silicone around the harness connector when I flipped it and screwed it back in. I could see that if there was a crack or air leak around the connector and/or cover, extra air could leak into the throttle chamber a wreak havoc on the sensors accuracy to the ECU.
__________________
Old 05-15-2011, 07:20 PM   #9
Points: 19, Level: 1
Points: 19, Level: 1 Points: 19, Level: 1 Points: 19, Level: 1
Activity: 1.3%
Activity: 1.3% Activity: 1.3% Activity: 1.3%
Same Problem / Symptoms
Hi, I've been having the exact same symptoms and problems with stalling at idle and bucking at higher RPMs. I have looked at the solder points and connections within the MAF, and they all look solid and clean. OP, did you have a broken contact or bad solder that prompted you to modify the connection?
Also, in case that isn't the problem, does anybody have any other suggestions as to what could be causing the problem? I have a p0100 code, I have read and tested the voltages/readings, grounded the MAF, etc., and nothing has worked yet. The problem is intermittent. For example, I could leave the car running for 20-30 min sometimes with no problems, and then randomly it will just stall and shut off. Also, driving at higher RPMs does not ALWAYS cause the bucking. That is also intermittent and happens only some of the time. Although, when it happens, it basically makes the car undrivable. Any help/assistance is appreciated. Thanks!
Tyler89 is offline   Reply With Quote
Old 05-15-2011, 08:21 PM   #10
Activity: 0%
Yep sounds just like what mine was doing... The connections will LOOK just fine, but I suspect they all eventually fatigue and become cold soldered at some point. I can tell you I have not had a problem since I did my modification. Try this experiment with the car idling normally, apply some pressure on the air filter housing and she if engine stalls, stumbles, or dies. This will confirm the poor/cold/fatigued connections. Good luck and let me know how it goes. Also beware of those cheap oem MAF's out there. I tried one at one point and the engine ran sorta OK at above idle rpm's, but idle was lousy! I finally just returned it and took a hit on the shipping and re-stock fee, but it gave me the opportunity to fix my original and put it back in. It's still running rock solid.
__________________
Old 05-18-2011, 09:15 AM   #11
Points: 4,497, Level: 42
Points: 4,497, Level: 42 Points: 4,497, Level: 42 Points: 4,497, Level: 42
Activity: 0%
This is why all of our MAFs fail, its simple, vibration (bumps and potholes) slowly kill the MAFs and the original welds begin to deteriorate. In my 5 years of owning my 96 I have been thru 2 MAFs, and usually right after I hit a road imperfection on the highway the car would buck real quick and then return to normal.Eventually it gets worse and worse until you either have to re solder the 3 welds like Maxirob did or just buy another off the classifieds like I did. Re soldering it would be a more permanent solution depending on how its done though. However for around 40 bucks you can just buy a used one be good for another 10 to 50,000 miles :]
__________________
________________________________
2000 Nissan Maxima GXE AT
Silver
New Headlights
Clear corners and clear sidemarker lights
Check your codes ! http://vbxmaxima.8m.com/ecudecoder.html
defiance is offline   Reply With Quote
Old 05-18-2011, 09:54 AM   #12
Activity: 0%
To add to what [defiance] said, if you think about it the air cleaner housing is mounted to the chassis (albeit on rubber bushings) and the MAF housing is under constant stress as the engine vibrates and moves on it's mounts. I think as the engine mounts eventually wear out and allow more engine movement, this just places more stress on the MAF housing until those solder joints fatigue and cause issues.
__________________
Old 05-18-2011, 01:22 PM   #13
Activity: 4.8%
the reman MAF are simply old MAFs that have been resoldered and maybe a new wire element.
Old 07-15-2011, 09:32 AM   #14
Points: 1,722, Level: 24
Points: 1,722, Level: 24 Points: 1,722, Level: 24 Points: 1,722, Level: 24
Activity: 0%
My 95 Maxima GLE has been having stalling, chugging and bucking problems for over a month but no codes what so ever.
I'm going to attempt resolder my original MAF as shown luke95gxe's pic above to see if that fixes my problem.
pwmaxgle is offline   Reply With Quote
Old 07-15-2011, 11:35 AM   #15
Activity: 4.8%
yup give it a try
Old 08-08-2011, 11:16 AM   #16
Activity: 0%
I bought a soldering tool kit from a local Radio Shack and re-soldered 6 points shown in luke95gxe's pic. My GLE ran about 200 miles with re-soldered MAF and so far performance has been rock solid!
Random stalling at idle, chugging and bucking at around 2000 rpm issues without CEL has not reproed for me so far. Hope my Maxima will continue to run rock solid with re-soldered original MAF.
I really appreciate .org members for sharing this MAF solution resources.
MAF issue was a very unique problem for me to to diagnose on my Maxima because I didn't have a single CEL code and all other mechanical areas looked good but that random stalling at idle, chugging and bucking around 2000 rpm problem drove me crazy...
Also purchased a used a MAF from .org classfied so I have a back up MAF for future MAF issues.
Old 08-08-2011, 12:09 PM   #17
Activity: 4.8%
no doubt man. Rock on!
__________________
Quote:
Originally Posted by njmaxseltd View Post
These forums are for ideas, help and suggestions to help you troubleshoot.
Quote:
Originally Posted by cashoit View Post
Ahhhh yes the magic of the Chevron Techron lol
To all u newbies out there a word of advice....Keep you MAF clean
Old 04-24-2013, 10:30 AM   #18
Points: 4,532, Level: 42
Points: 4,532, Level: 42 Points: 4,532, Level: 42 Points: 4,532, Level: 42
Activity: 0%
[i had to resolder these cicled points and it solved my issue but make sure U RESEAL THE MAF i did not and condensation got in and it made the car feel like i was misfiring i had another maf laying around put it in and solved that issue also could have saved the trouble by RESEALING THE MAF with some silicon hope this pic helps......]
i've 97 maxima that just gave P0100 code relating to MAF sensor. I have no stalling problems. Any one with ideas of cause and solutions? Thank you very much.
I have the code since recently disconnecting the battery and reconnecting it back. A few weeks back I cleaned the EGR guide tube, replaced the KS, changed ATF after replacing filter and cleaning drain pan, replaced fuel filter. It was working fine earlier P0350 & P0400 codes are gone. I believe these have nothing to do with P0100.
I love the forum with so many happy to help and knowledgeable people
signals is offline   Reply With Quote
Old 04-24-2013, 10:42 AM   #19
Points: 2,115, Level: 27
Points: 2,115, Level: 27 Points: 2,115, Level: 27 Points: 2,115, Level: 27
Activity: 4.4%
Activity: 4.4% Activity: 4.4% Activity: 4.4%
Nice fix. I had the same problem. Went to the dealer and got slapped with a $500 answer for a new MAF.
Went to the junkyard and bought a MAF from a Maxima there for $40 and solved the issue .
catalinvint is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
