Car starts and restarts within 1 minute but wont start after
Today my car wouldn't start and ended up finding that if I disconnected my battery, waited a little bit and hooked it up that it started and ran fine. Now is where it gets weird. When I turn my car off and restart it within 1 minute, it will start just fine. When I turn my car off and restart it after 1 minute, it wont start.
What on earth could be causing that to happen??
I am beyond stumped on this one.
When you are trying to start it up, is the starter cranking over the engine? If your answer is yes check your crank pos sensor behind the crank pulley. There is another one on the bell housing of the trans. Remove them and refer to FSM for how to test them with a digital voltage meter and might as well test the cam pos sensor to located close to the top of the timing cover. Remove it and test it. I'm not saying for sure this is the problem but it is a start. Check the basics for vac leaks, spark, fuel, fuel pressure and check grounds for clean and good connections. Hope this helps you out.
The starter is not cranking at all when it doesn't start.
Now even when I disconnect the negative, wait and reconnect it the car will no longer start.
Unfortunately I have about 2 tools (left and right) and as a college kid living in an apartment, I have little resources to do much over the basics.
I could have it towed to a shop, but I am afraid that I am going to get a crenshaw punch in the nads in costs for diagnostics.
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
MaximaDrvr
08-19-2015 08:20 PM
kirkhilles
08-08-2015 10:53 AM
