burnt oil smell in my a/c
Old 06-07-2011, 06:22 AM
joseph.mcgowen's Avatar
if i drive for a while and turn the car off when i turn it back on with the a/c on i can smell a slight burnt oil smell coming from the a/c vent it only happens if the a/c is on i haven't checked the codes yet but i had it scanned a few weeks ago and i was pulling a p0300 i did the valve cover gasket and plug well seals because i believe that was my problem but now i still have a leak somewhere along the backside of the motor and i cant figure out where has anyone had this problem and could this could the a/c be sucking up the burnt oil fumes
joseph.mcgowen is offline
Old 06-07-2011, 06:25 AM
Crusher103's Avatar
BOOM.
Crusher103 is offline
Old 06-07-2011, 07:31 AM
cashoit's Avatar
well if u dont smell it with the AC on or if the AC is cold, at least it hasnt infiltrated your ac lines
cashoit is offline
Old 06-07-2011, 07:33 AM
Dcarlton's Avatar
When you redid the rear valve cover gasket, did you use sealant on the corners as specified by the FSM? If not, it will still leak ( I didn't know about the use of sealant until after I did mine and read the FSM and discovered this - yes, it's also well documented here in the forums too).
Dcarlton is offline
Old 06-07-2011, 12:47 PM
i didnt use sealant the first time so i had to redo it and that is not were the leak is anymore
Old 06-08-2011, 02:39 AM
Cielo's Avatar
clean the engine and let it idle for about 5 minutes in place. turn it off and you should be able to get under your car and see where the leak is. if you run your car its harder to find a leak since wind spreads the oil. it could be shooting from somewhere completely different and getting sprayed on your exhaust manifold in the wind.
Cielo is offline
Old 06-08-2011, 07:19 AM
max ride 41's Avatar
what????
max ride 41 is offline
litch
123
01-04-2024 07:01 PM
Miket2006
03-01-2021 03:55 AM
mclasser
22
11-12-2020 01:58 PM
06-06-2017 02:01 PM
05RLS2
04-14-2016 11:49 AM
Quick Reply: burnt oil smell in my a/c
