EGR Valve Problems
Old 10-02-2011, 02:07 PM
ef9
ef9's Avatar
EGR Valve Problems
I am wondering if my EGR valve is not operating properly. When the car is idling, I can hear the EGR valve tapping erratically. I pulled vacuum on the EGR, and it seems to be okay (Haynes manual), as well as the EGR control solenoid valve, the EGR BPTC.
Stan
ef9 is offline
Old 10-02-2011, 06:35 PM
DennisMik's Avatar
The metal tube on the EGR valve tends to get plugged up. Maybe that's what has happened to yours.
DennisMik is offline
Old 10-02-2011, 06:47 PM
cartman854's Avatar
Wouldn't cause valve probs. The guide tube is in a different system. Usually the EGR valve has a CEL when it breaks. Check the connection on the green sensor by the KS.
cartman854 is offline
Old 10-02-2011, 11:47 PM
ef9
ef9's Avatar
Thanks for the responses. The tube was super cleaned when I did the overhaul on my engine.
I will check that connector to the EGR solenoid valve. I did check the valve for proper operation. But I guess I should check the connection too.
ef9 is offline
shilov
02-19-2024 09:40 PM
trailer54
Nitrous
11-18-2015 07:44 PM
Max139617
09-20-2015 07:25 PM
DarjeelingRose
09-15-2015 01:20 AM
tardrex
09-11-2015 07:35 PM
Quick Reply: EGR Valve Problems
