For those of you who have done a clutch job....
Old 03-30-2011, 08:04 PM
99BlackMaxMS's Avatar
Hey guys,
How many of you dropped the crossmember?
I am just curious because if I need to do a clutch in the future, I fear that if I take the the bolts off on the crossmember/core support, that I will never be able to get them back in, and be stuck doing a core support at that moment. I plan on replacing the core support soon too.
So was anyone able to access the shift linkage bolts without dropping the crossmember and successfully do the clutch job without removing it?
Thanks guys,
Matt
99BlackMaxMS is offline
Old 03-30-2011, 08:30 PM
Product_Of_Korea's Avatar
go for it. Totally doable without dropping the cross member
Product_Of_Korea is offline
Old 03-30-2011, 08:51 PM
luke95gxe's Avatar
i did it last year didnt remove cross member didnt remove exhaust either pretty easy helps if u have some help i had none it took me bout 4 hours i had impact tools so that helped and a garage
luke95gxe is offline
Old 03-30-2011, 08:58 PM
Okay cool. I've done 2 clutches on this car already and both times I took the crossmember out. I was pretty sure the 2nd time I did it I realized how it seemed unnecessary, but I just haven't had a chance to get under the car to look.
Old 03-30-2011, 09:06 PM
Blackwind's Avatar
i never touch the cross member, i can get it done in 2 hours now.
Blackwind is offline
luke95gxe's Avatar
i believe that bolt on the shift linkage is a 14mm and u can get a off set wrench and it comes off fine seems tight but it is ttaly doable
Old 03-30-2011, 09:20 PM
4th Gen Parts King
Maxima_Joe's Avatar
You'll be fine not removing the cross member with a manual.
Maxima_Joe is offline
Old 03-31-2011, 07:35 AM
this place is dead
97SEdriver's Avatar
Hey guys,
Thanks guys,
Matt
I just think it makes getting the tranny off way easier, but I understand your dilema. I dropped mine to put in bushings while removing the tranny, I forgot I had bought the bushings, so even thought I didn't want to drop the crossmember, in the end it made my life easier.
97SEdriver is offline
Old 03-31-2011, 07:39 AM
this place is dead
97SEdriver's Avatar
Yes, I will agree with that statement
Originally Posted by 97SEdriver
Everyone b1tches about the hard to reach bolt on the shift linkage support, do yourself a favor and get one of these.
offset box wrench, $7-8 even if you buy craftsman.
and Evapo-rust works...use it or something like it to soak every nut, bolt, and whatever you can, makes life easier putting things back together.
Old 03-31-2011, 02:17 PM
I'm nutty for Nissans
JSutter's Avatar
Ratcheting wrenches work wonders.
Spare 12mm, IIRC, ground down for better access to the drain plug.
JSutter is offline
Old 03-31-2011, 02:57 PM
Dbird's Avatar
Don't have to remove the crossmember. Done it bout 4 times and never messed with the crossmember. With the right tools, its easy.
Dbird is offline
Old 03-31-2011, 03:14 PM
i has college
EnervinE's Avatar
I didn't drop it, but loosening the two crossmember-frame bolts at the front just a half inch or so was the only way to get the lower bellhousing bolts out. Otherwise they were trapped in by the crossmember. The clearances were so close though that you may not run into this problem.
EnervinE is offline
hcarter1112
42
07-18-2022 03:35 PM
03-12-2020 12:06 AM
spencerwh1
06-30-2016 05:44 AM
BkGreen97
04-02-2016 05:47 AM
carlosvq30
09-26-2015 09:44 AM
Quick Reply: For those of you who have done a clutch job....
