remote truck pop install with a few pics
Old 01-22-2011, 01:52 PM
luke95gxe's Avatar
okay so i saw a thread on here a while back about a remote trunk pop and i have been thinking bout doing this myself as my 95 gxe didnt come with it. so i went to the junk yard i didnt want to have to get a door panel with the pop already in it so i just got the push button switch, brown relay, and the trunk solenoid all the wiring is already there.so this is what needs to be done.
one remove door panel and cut a hole for the switch i used a drill bit on a die grinder and started small until it fit. the wire connecter for the push button is behind the door panel taped in blue tape
once u get it fitted move on to the trunk you will need a 10mm socket pop the carpet off to gain access to the trunk latch and remove the cable that pops the trunk you will see the brown harness for the relay and the connector for the trunk pop solenoid u need to put the soleniod in there are 2 holes already in the latch assembly for it hook the cable of the solenoid in the latch and mount the solenoid then put the relay in and connect the solenoid i have a aftermarket alarm with aux so i programmed it to open the trunk here are a few more pics so you get an idea hope someone can use this info
the solenoid
the relay
this is how it should look mine works and i love it hope this helps someone
oh dont forget to sand the metal where the solenoid bolts up
luke95gxe is offline
Old 01-22-2011, 01:54 PM
95Maxed's Avatar
Someone Sticky this, good job
95Maxed is offline
Old 01-22-2011, 01:55 PM
MizzMaxine's Avatar
Clean work.
MizzMaxine is offline
Old 01-22-2011, 02:30 PM
Another great write-up from Luke. Good job buddy
ChrisMan287 is offline
Old 01-22-2011, 02:36 PM
luke95gxe's Avatar
yes sir thank you i have learned so much from the org and its members just want to give back a lil
Old 01-22-2011, 03:16 PM
Dave H.'s Avatar
I always thought 4th gens came stock with them, at least my two do.
Learn something new everyday.
Dave H. is offline
Old 01-22-2011, 05:39 PM
kel456's Avatar
luke95gxe, great pics and info. i assume the manual lever release is still functional? which wire did you tap for the alarm aux?
kel456 is offline
Old 01-23-2011, 03:26 PM
luke95gxe's Avatar
naw the manual lever is non functional thats what the button in the door is for it opens the trunk from the inside of the car now. i tapped in to the solenoid its self for the remote
Old 01-24-2011, 05:12 PM
BigRek718's Avatar
great job, if by any chance my max doesn't come with on this should help.
BigRek718 is offline
Old 01-24-2011, 05:30 PM
max ride 41's Avatar
se's and gle's did, i think it was just the gxe's that did'nt
max ride 41 is offline
Old 01-24-2011, 06:34 PM
Quickywd01's Avatar
GXE must have some serious weight reduction.
Quickywd01 is offline
Old 01-24-2011, 08:20 PM
nismomaxgtr18's Avatar
My 98 SE didn't come with it unfortunately lol.
Great job OP.
nismomaxgtr18 is offline
Old 01-24-2011, 09:22 PM
Great job OP.
i think it was an option for se's maybe?? cause they had the sport package the gle's got all the other stuff like moonroof and leather heated seats with remote entry and abs. se's got the spoiler and the fogs of which i have neither.
Old 01-25-2011, 08:20 AM
pavelsmax's Avatar
My GXE came with it, along with variable int wiper, power driver seat, and sunroof. Perhaps that was some type of package offered for GXE's?
Anyway I had no idea this wasn't standard either, nice writeup in case my next 4th gen doesn't come with this.
pavelsmax is offline
Old 01-25-2011, 08:40 AM
cashoit's Avatar
No In-cabin Trunk release? Every car comes with one. Why wouldnt a max come with one.
NOw if its brokent thats a diff story...
On subject,
Good work Luke man.
cashoit is offline
Old 01-27-2011, 07:53 AM
luke95gxe's Avatar
On subject,
Good work Luke man.
thanks i had a in cabin trunk release it was just a lever on the floor but i wanted a remote trunk pop so hence the upgrade
Old 01-27-2011, 08:56 PM
j-dawg's Avatar
I'm always surprised by what wasn't standard on these cars. I realize it was fifteen years ago, but damn, no intermittent wipers, no electric trunk release. The one that perpetually astonishes me is that it was possible, by 1997, to buy a car that did not have ABS, especially one which is supposed to be an entry-level near-luxury sport sedan.
j-dawg is offline
Old 09-26-2016, 05:57 PM
luke95gxe's Avatar
Originally Posted by Mrazouan
So doing this mod would make it so the manual trunk release no longer works?
What if you just put the actuator in and have your keyless wired up to it via relay with your keyless entry module brain.
Yes it will make the manual pull lever not work you cant do just what you saiD but if you have a fob and keyless entry this would be standard on your vehical
Finkle
09-27-2015 09:53 PM
seesole
08-26-2015 11:22 AM
FanaticMadMax
08-10-2015 08:55 PM
kirkhilles
08-08-2015 10:53 AM
maximaham
08-07-2015 01:11 PM
Quick Reply: remote truck pop install with a few pics
