Possible damaged strut?
I recently had my struts replaced, and I have noticed that the lock nut on one of the struts, doesn't appear to be tightening correctly. The nut and the shaft of the strut appear to be spinning together. Is this a bad strut, or is the strut mount defective?
Sounds like the strut mount needs to be replaced. There's a notch (for lack of a better vocabulary) in the shaft and in the mount which should hold the shaft from spinning when you tighten the nut. Either that notch has worn away or your strut was not installed properly.
MaxLvr21
10-17-2015 12:11 PM
maxima-junky
10-07-2015 06:13 PM
