Ignition coil connector broke...options?
Old 01-15-2011, 09:05 PM
beegeezy's Avatar
So, after 150k and plenty of hot TX summers my coil connectors are pretty brittle. I was changing my plugs yesterday and the retaining tab on the #1 coil broke. I have it zip-tied to keep it on for now. Does anyone sell replacement connectors that I can solder and shrink tube? I looked on courtesyparts and didn't see anything.
beegeezy is offline
Old 01-15-2011, 10:50 PM
asand1's Avatar
Go to the wrecking yard and harvest some connectors. You should be able to pull the wires and terminals out of your old connectors and insert into "new".
Also here http://www.fiveomotorsport.com/elect...s/?itemid=1231
Google can be your friend. Search injector connector.
asand1 is offline
Old 01-16-2011, 06:37 AM
jholley's Avatar
In the 4th GEN classified section put a WTB ad for a coil pack pigtail.
I placed an add there last March when I broke a coil pack and received a used OEM within a week.
jholley is offline
Old 01-16-2011, 03:50 PM
beegeezy's Avatar
Thanks guys...I appreciate the suggestions. Asand1, I would prefer to just re-pin some new connectors. Cutting and soldering is easy for me too. Those are injector pigtails not coil pack connector that you linked. I'm just worried that used connectors will be just as brittle.
beegeezy is offline
Old 06-25-2012, 01:32 PM
mitch09's Avatar
I am also looking for a connector or two for these ignition coils if anyone can help!?
mitch09 is offline
Old 06-25-2012, 01:35 PM
ShocknAwe's Avatar
I can go to the pull a part and pull a bunch if you guys need them. Just not sure when I am going next and it would cost me more in gas than yall are willing to pay for them
ShocknAwe is offline
Old 06-27-2012, 05:02 PM
mitch09's Avatar
i got some coming from someone else on the forums thanks, is it easy to repin the connector? or is it easier to have it come with extra wire attached and just solder the wires together?
mitch09 is offline
Old 06-27-2012, 07:11 PM
asand1's Avatar
Will these fit?
http://boostpro.net/prodz32coil.html
asand1 is offline
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
AaronL
08-08-2020 10:31 AM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: Ignition coil connector broke...options?
