Idle Issue???
Idle Issue???
So i think i have a problem. After i cleaned my Tb and Iacv i felt like my idle might have went up. It wasnt loud like it is now when i turn on the car. And everytime i turn it on if its not warm it idle's at 1500 and slowly drops down. My mileage on the gas is horrible i have to put 15 dollars every other day and i only use the car for street purposes only. Im leaning on a knock sensor Problem i need some info about this Thanks
Heres the link to the video
http://www.youtube.com/watch?v=YbEKqd9vX4o
on a cold start thats what its supposed to idle, it should should start around 1500, then a couple seconds later creep down to around 1200ish and then a few seconds later to normal idle
if youre idling at 1500 stopped when the car is warm thats a problem, if thats the case you can adjust the idle
Tighten to drop it. You can adjust it while its idling.
I can check for a knock sensor code for you at the meet. They dont trip an SES light.
It's normal! But if you really want to adjust the IACV, turn the car on and turn that screw to the right, it'll lower the idle.
op u cleaned every thing that was gunked up an now ur car is doing what it is supposed to do u could adjust it if u want thats a personal decision
Perfect today i woke up and i cleaned the T/B and IACV again and Idle is perfect. The car runs fine but ill wait till the meet so dough can check the knock sensor. I don't think any more adjustments need to be made as in messing with the **** in the IACV. Thanks a lot fellow orgers. Pleased to be in a community that is very helpful.
bryants95max
10-02-2015 12:52 PM
97_GXE
20
09-17-2015 08:12 PM
ballerchris510
09-10-2015 09:35 PM
