Cruise control
Old 06-02-2016, 07:52 PM
ShunDoe's Avatar
Cruise control
Cruise control stopped working out of nowhere. I want to say it was around the time I had my brakes replaced. What crazy is a friend of mine had a Infiniti Q45 and the same thing happened, his cruise control quit working. Any solution?
ShunDoe is offline
Old 06-03-2016, 06:10 AM
lux97Max's Avatar
Worth a try
lux97Max is offline
Old 06-03-2016, 08:13 AM
ShunDoe's Avatar
Originally Posted by lux97Max
ShunDoe is offline
Old 06-03-2016, 08:54 AM
rayz336's Avatar
Were there any black plastic pieces in the driver floorboards? If so, there's a plastic nub under the steering wheel that needs to be replaced and it's not much at the dealership. Maybe 5-10 dollars and it just pops into place.
rayz336 is offline
Old 06-03-2016, 10:19 AM
bumpypickle's Avatar
is your speedometer working? If it doesn't work, the cruise control wont work
bumpypickle is offline
Old 06-03-2016, 08:09 PM
ShunDoe's Avatar
My speedometer works, but my tachometer goes crazy
ShunDoe is offline
Old 06-03-2016, 09:38 PM
DennisMik's Avatar
This is probably the most likely cause.
The only thing is - the plastic "nub" is on the brake pedal, not the steering column. It operates a switch that cancels the cruise control when you step on the brake pedal.
DennisMik is offline
Old 06-03-2016, 09:59 PM
Fakie J Farkerton's Avatar
This is probably the most likely cause. The only thing is - the plastic "nub" is on the brake pedal, not the steering column. It operates a switch that cancels the cruise control when you step on the brake pedal.
Is this another potential penny fix situation?
Same type of fix for when the brake lights act up/stay on?
Penny fix is affordable.
Fakie J Farkerton is offline
Old 06-04-2016, 11:17 AM
DennisMik's Avatar
Yes.
Mattman998
05-28-2016 08:49 AM
JoeyChrome
22
05-27-2016 12:46 AM
Tyler199580
05-21-2016 02:12 PM
ONE BAD Maxima
05-15-2016 01:40 PM
barristan
05-07-2016 07:53 PM
Quick Reply: Cruise control
