another "birds chiripin under the hood"
so..it started yesterday morning...started the car and heard what sounded like chirping under the hood, its obviously coming from the area around the belts..
- my crank puley vibrates at idle...but its done that since i got the car a year ago... my belt was loose months ago, tightened it, *squeel* gone, but this is chirping, sounds like birds under my hood,when i rev it, it just gets faster and a little higher pitch, but dies down to a constant chirp at idle, i did research on it but coulldnt find anything to narrow it down enough...:/...tomorow i will see if my crank pulley is loose to the touch and will try tightening it when everything is torn apart for my clutch.
- ive read about maybe bearings, water pump, or just a bad pulley in itself, any advise is helpful thanks!
1. is there a way to check to see if the pully is going? other than taking the belt off, spinning each individual pulley to see if it squeaks?
2...and yea you know i kill the birds and stick them in my sub box to make it bump harder, literally....haha no
metallic97gxe
05-02-2002 08:49 PM
mike-777
08-10-2001 12:05 PM
Omegasrk
02-22-2001 10:16 AM
