95 Maxima rear speaker wire polarity
Old 11-16-2010, 01:08 PM
jobell's Avatar
Anybody know what wires the "+" and "-" are for the rear speakers in a 95 Maxima(non Bose)???
Joe
jobell is offline
Old 11-16-2010, 01:23 PM
ampire's Avatar
Take a battery and some scrap wire, run the positive end of the battery to one terminal and the negative to another. If the cone moves out, its wired correctly and if it moves in its wired incorrectly, so then by process of elimination figure out which is positive and which is negative.
If you are looking at the wire not the speaker, usually the negative wire in a automotive audio wiring harness has a black stripe.
ampire is offline
Old 11-16-2010, 02:21 PM
tigersharkdude's Avatar
or the speaker has a - by one terminal and a + on the other
tigersharkdude is offline
Old 11-16-2010, 03:13 PM
No more Maximas...
pmohr's Avatar
pmohr is offline
Old 11-16-2010, 04:49 PM
beegeezy's Avatar
Other than looking at the wiring diagram this is the easiest way.
This is ONLY correct in AFTERMARKET wiring, not in factory wiring. NEVER assume a original wire is negative because it has a black stripe.
beegeezy is offline
Old 11-16-2010, 04:57 PM
jobell's Avatar
Originally Posted by pmohr
Thanks for the schematic. That's exactly what I needed!!!
jobell is offline
jskirwin
06-08-2016 08:49 AM
Huttig2009
09-25-2015 03:31 PM
Maxilano
08-31-2015 07:33 PM
Mcnabb34
08-11-2015 08:45 PM
MikesChevelle
08-09-2015 11:50 AM
Quick Reply: 95 Maxima rear speaker wire polarity
