Turn the key and nothing happens...
Old 10-09-2010, 02:15 PM
Crushed's Avatar
I've been having this problem for some time. I would turn the ignition switch and my max would just sit there, no cranking sounds or anything...it would eventually start up after a few tries. I've noticed that it usually does it after sitting in the heat for awhile during the day...never had the problem before at night when its cooler. Its definitely not the battery....could it be spark plugs? changed them like 4-5yrs ago...not sure how often they should be changed. Thanks
Crushed is offline
Old 10-09-2010, 02:34 PM
luke95gxe's Avatar
prolly the ignition switch cheap and easy fix
luke95gxe is offline
Old 10-09-2010, 02:39 PM
Mr.A32ftw's Avatar
+1. Had the same problem and it turned out to be the ignition switch
Mr.A32ftw is offline
Old 10-09-2010, 03:50 PM
hornepirate's Avatar
Holy crap do you noobs ever read or search?!?! There have been 3 or 4 of these threads in the past 2 weeks about "I start my car and nothing happens"
It is your ignition switch more than likely...go to auto zone $20 replace it. If you don't know how to replace it.....SEARCH
hornepirate is offline
Old 10-09-2010, 06:32 PM
LtnMAXX's Avatar
well its probably the IGNITION SWITCH..or like in my case, it was my BATTERY TERMINALS. being that their 15 yrs old, they get loose
LtnMAXX is offline
tarun900
19
12-20-2021 06:57 PM
gavin68
09-18-2021 12:36 PM
06-06-2017 02:01 PM
Fbana41
08-29-2016 12:18 PM
RealityCheck
10-02-2015 06:34 PM
Quick Reply: Turn the key and nothing happens...
