Foglights
Old 11-08-2000, 10:05 AM
clee130's Avatar
I have a 95 gxe and I was wondering what are my options when it comes to foglights.
Obviously the cheapest way would be to get some aftermarket foglight and install them.
But what about getting a new bumper and them getting OEM foglights?
Or what about cutting a hole where the foglights should be and then putting in OEM foglights?
clee130 is offline
Old 11-08-2000, 10:11 AM
Cumalot's Avatar
Best thing is to get OEM foglights. I have a SE, so it was standard. Get the OEM fogs, it look much better. I'm not sure how much it cost, but try not to get them from the dealer because they're going to be expensive.
Cumalot is offline
Old 11-08-2000, 10:13 AM
Che
Che's Avatar
that will work just fine
there should be a cutout pattern where stock fogs go...you can cut there and just install the stock fogs which look best imo. don't know if you need wiring or anything else to do it....just know that it can be done....maybe someone here has done it and can help you out.
Che is offline
Old 11-08-2000, 10:24 AM
OG
SmoothMax's Avatar
I don't know too much about the whole wiring thing, however i do know that the dealer is gonna charge you two arms and three legs for oem foglights. Your best bet is to look around and see if a junkyard, perhaps, in your area has maxima foglights. Don't forget to check the parts for sale forum either.
SmoothMax is offline
Old 11-08-2000, 10:52 AM
Wayne
I've done it! it was not that bad. I bought them for courtesy nissan and I installed them myself.All the wiring is there. the hardest part was cutting the bumper. once I got that cut It was all plug and play. I think I payed about $160-180 soome where in that area I didnt care too much about the price I wanted the OEM look. Its not hard to do.
Old 11-08-2000, 11:03 AM
clee130's Avatar
What did you use
to cut the bumper?
And the foglights turn on only when the headlights are on, right? Is there anyway to turn them off when the headlights are on?
Cause in my dad's Pathfinder, the foglights will only come on when the headlights are on, and there is a switch to turn the foglights on and off.
clee130 is offline
Old 11-08-2000, 11:22 AM
Wayne
The bumper is plastic so I cut it with a breakaway knife.As far as the fog lights beening on it comes with a switch that replaces the OEM turn (came with the fogs). the new one has the head lights and the fogs all on one lever.you can turn the fogs off even if the head lights are on. I rewired mine the same day I installed them to come on with the park lights and you can still turn them off if I dont want them on.
Old 11-08-2000, 01:52 PM
drewm's Avatar
One thing about the OEM fogs...
Try not to put too high of wattage bulb in those enclosures, I use to run APC 100W bulbs in them, and after running them about 20 minutes, you could't even touch the glass on the enclosures without burning your finger. Eventually after 1.5 months, one of the bulbs burned out on me. Also when I took the good bulb out, the bulb was all clouded up (I don't think it liked the 5.5 hr drive from the bay area to LA). I'm back to stock fog bulbs and they run much cooler now.
drewm is offline
Old 11-16-2002, 10:48 PM
maximumpower96's Avatar
i have a pair for 95 foglights.. if intrested email me @ :Maximumpower96@aol.com.
Thanx
Sal
maximumpower96 is offline
Old 11-16-2002, 11:23 PM
SuDZ's Avatar
Wow... this thread came back from the dead.
SuDZ
SuDZ is offline
Old 11-17-2002, 12:03 AM
Former Sponsor
carnal_c30's Avatar
jeeeesus... thats OLD!
carnal_c30 is offline
Old 11-17-2002, 12:32 AM
TylerBorg's Avatar
anybody with aftermarket fogs like them,, $$$ is an issue for me
TylerBorg is offline
Old 11-17-2002, 12:54 AM
Mishmosh's Avatar
Contact JRNissan for their $200 shipped 95-96 OEM foglight kit that includes brackets, foglights, etc. Your car already has the wiring harness for them.
Mishmosh is offline
Old 11-17-2002, 08:18 AM
deezo's Avatar
Clee doesn't even have this car anymore.
deezo is offline
Old 11-17-2002, 10:03 AM
tbannon's Avatar
i just bought after market fogs b/c $$$ was an issue to. I don't think they are bad. You can't even see mine when they aren't turned on b/c my home depot grill covers them up. I bought cyberwhites from wal mart for 30.00. They also sold cyberwhites that came with a remote control for your key chain for an extra 10.00
tbannon is offline
Heat0212
10-24-2020 12:36 AM
ricky7780
11-03-2015 03:22 PM
Excalibur23
10-13-2015 04:33 PM
Hdnseek
09-09-2015 05:55 AM
fc95se
11-15-2000 05:14 AM
Quick Reply: Foglights
