Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 09-10-2010, 10:50 AM   #1
Points: 5,583, Level: 48
Points: 5,583, Level: 48 Points: 5,583, Level: 48 Points: 5,583, Level: 48
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
changed spark plugs and lost power!!
I replaced my spark plugs with Bosch Platinum +2's. When I turn the car on, I feel some shaking and sputtering. When I drive it, it has no power at all. I floored the gas pedal and it slooowwly accelerated. WTF is going on? I double checked to make sure I connected all the sensors already. Help!!!
canIlive is offline   Reply With Quote
Old 09-10-2010, 10:54 AM   #2
Points: 9,610, Level: 65
Points: 9,610, Level: 65 Points: 9,610, Level: 65 Points: 9,610, Level: 65
Activity: 0%
Send a message via AIM to xkazik
bosch plugs arent good for our car , you should replace them with NGK and you should be good to go
xkazik is offline   Reply With Quote
Old 09-10-2010, 11:26 AM   #3
Activity: 0%
when you say they aren't good for our car, do you mean they will do damage? do you think the cause of loss of power and sputtering is due to Bosch plugs?
Old 09-10-2010, 11:35 AM   #4
Points: 3,285, Level: 35
Points: 3,285, Level: 35 Points: 3,285, Level: 35 Points: 3,285, Level: 35
Activity: 0%
Send a message via AIM to redcross631 Send a message via Skype™ to redcross631
idk if bosch spark plugs will cause damage to our cars...i just know they're good for german cars n not japs....first thing to do, definitely try NGK platinums and see if it solves ur problem
is ur check engine light on or flashing ??
__________________
redcross631 is offline   Reply With Quote
Old 09-10-2010, 11:35 AM   #5
Points: 10,166, Level: 67
Points: 10,166, Level: 67 Points: 10,166, Level: 67 Points: 10,166, Level: 67
Activity: 24.1%
Activity: 24.1% Activity: 24.1% Activity: 24.1%
No and yes. They shouldnt do damage. NGK is OEM for our cars and its been documented many times that Bosch dont run for **** in the VQ.
__________________
Download NISSAN Maxima Factory Service Manual here
Maximustang--1996 Maxima SE--
asand1 is offline   Reply With Quote
Old 09-10-2010, 11:39 AM   #6
Activity: 0%
By the way fellas, now my car won't start at all!!!!!
Old 09-10-2010, 11:40 AM   #7
Activity: 0%
Yes, my SES light is on but it's been on for a while due to an EGR valve issue.
Old 09-10-2010, 11:43 AM   #8
Activity: 24.1%
Change the plugs and try again. Might have been a difference between resistor/non-resistor or something. Possibly cooked the coils. Hard to say without knowing all the details. What part# were the Bisches?
__________________
Old 09-10-2010, 11:57 AM   #9
Activity: 0%
yes change the spark plugs and reset the ecu to get rid of the codes...
my brother's Lexus ES was being like that recently...wen't on ahead to change the spark plugs n 3 of them had oil on 'em due to bad seals....replaced the seals n spark plugs n it started running like new again...don't knw if yew have da same problem but yew should check anyway
find out what other codes is da car throwin at yew
__________________
Old 09-10-2010, 12:01 PM   #10
Activity: 0%
Quote:
4303
Old 09-10-2010, 12:01 PM   #11
Activity: 24.1%
Your not texting and were not in da hood, please communicate like an educated person. This is a somewhat technical group and should be treated as such.
__________________
Old 09-10-2010, 01:56 PM   #12
Activity: 0%
that was unintentional...sorry about that
__________________
Old 09-10-2010, 02:27 PM   #13
Activity: 24.1%
I'm at work right now, If you post the Bosch #s I'll see what I can find out later.
No problem I don't mean to be grammar ploice, I just dont like to read posts where I gotta translate ghetto slang. You have a good point, if the tube seals are bad that'll soften up the plug boots and then replacing the plugs can cause a break in the insulation (boot).
__________________
Old 09-10-2010, 02:41 PM   #14
GOT RETROFIT?
Points: 16,961, Level: 83
Points: 16,961, Level: 83 Points: 16,961, Level: 83 Points: 16,961, Level: 83
Activity: 21.1%
Activity: 21.1% Activity: 21.1% Activity: 21.1%
Bosch plugs are absolute garbage for VQ's, I learned the hard way like you. Switch back to NGK coppers and you should be fine. All your problems will most likely be solved.
__________________
http://www.retrofits-r-us.com/
http://www.youtube.com/chrisman287
Quote:
In Carbon Fiber we trust. Amen.
ChrisMan287 is offline   Reply With Quote
Old 09-10-2010, 03:40 PM   #15
beegeezy's Avatar
Points: 7,901, Level: 59
Points: 7,901, Level: 59 Points: 7,901, Level: 59 Points: 7,901, Level: 59
Activity: 0%
Quote:
Those Bosch plugs are crap for any car. NGK or Denso will be much better. I have NGK coppers because they are cheap, copper is a superior conductor, and I don't mind changing plugs every 30k since I don't drive that often.
__________________
No Max, no more.
beegeezy is offline   Reply With Quote
Old 09-10-2010, 08:37 PM   #16
Points: 4,027, Level: 40
Points: 4,027, Level: 40 Points: 4,027, Level: 40 Points: 4,027, Level: 40
Activity: 3.1%
Activity: 3.1% Activity: 3.1% Activity: 3.1%
unless oil is in the chambers, in which case, order a VIM and call it a day like I did. (after you fix valve cover gaskets and seals of course.)
__________________
95 Maxima GLE
Performance: True CAI-Bomz Racing FSTB-Custom 2.5in-
Exhaust-WSP Y pipe-Grounding Kit-MEVI-NWP Spacers-TS ECU @ 7200 RPM
Audio: Alpine IDA-X305 MMDI and 4 Alpine speakers- 12" Kicker L3- 500W TMA amplifier
Exterior:Clear bumper lights-Removed Pinstripe-18" Muranos-Added OEM Fogs-Added OEM Spoiler-Red/Clears-20% tints-R34 Duels
Interior: Fixed Clock.
" Ya, I Mob my High School in a Maxima."
cartman854 is offline   Reply With Quote
Old 09-11-2010, 07:11 PM   #17
Points: 9,443, Level: 65
Points: 9,443, Level: 65 Points: 9,443, Level: 65 Points: 9,443, Level: 65
Activity: 0%
i been running NGK platinums runs great, but i just changed out old ones that had 30k miles on them and put new ones and i lost a lot of power myself, but i think its because dumb *** at autozone said i have to gap them even know their platinum tip and i ruined like 3 before i gave up and just put them in.
TravisCadello is offline   Reply With Quote
Old 09-12-2010, 06:45 AM   #18
Activity: 0%
thanks for the replies fellas. I am returning the Bosch plugs and buying NGK plugs. But, when I removed the plugs, one of them had oil on it. Is this a problem?? None of the other plugs had oil. Any ideas?
Old 09-12-2010, 09:15 AM   #19
Activity: 0%
change valve stem seals and valve cover gaskets.
Old 09-12-2010, 09:49 PM   #20
Points: 7,177, Level: 56
Points: 7,177, Level: 56 Points: 7,177, Level: 56 Points: 7,177, Level: 56
Activity: 10.1%
Activity: 10.1% Activity: 10.1% Activity: 10.1%
Quote:
Yes, that is a problem as your spark plug grommets inside your valve cover is no good. Gotta replace those along with your valve cover gasket. Travis, yeah that was a dumb move on their part as they are already gapped. I bought the NGK Iridiums and just place it in..
Trini Boom is offline   Reply With Quote
Old 09-13-2010, 07:44 AM   #21
I don't know if the spark plugs would do that because honestly I had my car brand new with 30 miles on it and a year after I bought I have use ONLY Bosch and I never had a problem ! know i think when you removed the spark plugs you might of moved or unplung something ! check everything and back track what you have done , maybe something else when bad and it jut happen that it happen when you replaced the spark plugs .Check the wires to the coils . hope this helps
__________________
The only thing necessary for the triumph of evil is for good men to
do nothing ...
Edmund Burke ..
Abimax95 is offline   Reply With Quote
Old 09-13-2010, 01:50 PM   #22
Points: 7,510, Level: 57
Points: 7,510, Level: 57 Points: 7,510, Level: 57 Points: 7,510, Level: 57
Activity: 0%
Save the money and get NGK copper (2$ each) ,you can never tell the performance difference from the plat.
And you MIGHT have another problem with the acceleration (apart from the brand issue)...NGK should work better,but Bosch shouldn't (not work) at all !!
mahanddeem is offline   Reply With Quote
Old 09-13-2010, 03:11 PM   #23
Activity: 3.1%
TO FIX:
Pull off all intake parts, and upper intake manifold, remove egr tube from UIM.
Order parts:
3x oil seal
1x rear valve gasket
1x TB gasket
1x IACV gasket
1x Upper manifold gasket
1x EGR gasket
This would be a good time to do a VIM swap like I did, also, get the 3 seals because you can just replace them all at once, its easy. Having oil in the sparkplug chamber is bad, once the old plug is pulled, the oil goes into the chamber and fouls the new plug, also, the oil blocks the power to the plug where it meets the coil, which could explain your poor performance because of a miss.
__________________
95 Maxima GLE
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
