Low cost sound deadening.
Old 08-22-2010, 04:35 PM
jasonaaronfox's Avatar
Did allot of research of all the current products available and found a few interesting things.
Dynomat is bloated and overpriced. For nearly the same product you can buy peel N seal which is nearly identical in composition and was created for roofing.
This got me onto a hunch. Looked into it and found out that back in the day, when cars were big block beasts with significantly more vibration and sound, manufacturers would use asphalt based roll roofing to sound deaden the cars. I tested this out, since I already had my interior out of my car to paint it black to match the leather seats I just restored, by taking out the sunroof panel that slides back and forth. I tapped it and listened to the sound it produced. Noisy, rattling, aluminum sound. I placed a sheet of aluminum foil against the side that faces up toward the roof of the car, glued it in place, then glued a smaller piece of 30 weight roll roofing in the center of the aluminum to create a damper. Over the entire thing I laid a large piece of 30 weight and glued it down. I lined it with some tape I had laying around (medical cloth tape,) and painted it with vinyl/fabric paint. Looked better than factory and reduced noise SIGNIFICANTLY.
Going to see how it works for the rest of the car.
As it is, it looks like it would cost roughly 10 cents per square foot using this method of backing asphalt roll roofing with aluminum foil.
jasonaaronfox is offline
Old 08-22-2010, 04:46 PM
dgoodhue's Avatar
Asphalt sound deadning material will smell like asphalt during a hot summer day. There are cheap alternative to dynomat (and you want one that has a good adhesive), but leave the roofing products to the roofers.
dgoodhue is offline
Old 08-22-2010, 05:35 PM
bamboomerang's Avatar
How much does it weigh?
bamboomerang is offline
Old 08-22-2010, 06:35 PM
I'm overcoming that by letting it cook in a few hot days with the interior out. So far so good.
Old 08-22-2010, 06:37 PM
Not too much. A whole roll can be picked up with one arm. Probably 30 pounds total.
Old 08-22-2010, 06:59 PM
dkillahster's Avatar
OMG
... Hmm, didn't i make a thread about this months ago?
Lemme find it.
dkillahster is offline
Old 08-22-2010, 07:04 PM
juschillr1's Avatar
I do a lot of systems and thats not really worth it. Tighten up everything get double sided tape for ur license plate. not the cheap one either. Also loosen the trunk latch and knock it down. so the the trunk shuts tighter.
juschillr1 is offline
Old 08-22-2010, 07:09 PM
j-dawg's Avatar
A lot of debate on Peel & Seal. Car audio products manufacturers are very active on car forums and spread a lot of FUD; it's not entirely unwarranted, but it's not always as bad as they make it out to be.
I Peel & Seal'd my front doors, but started with a thorough cleaning and sealed the edges and seams up with aluminum HVAC tape. Through what has been a disgustingly hot and humid summer, I haven't smelled an inkling of tar. I also stuffed the door panels with Frost King, google it for more info.
j-dawg is offline
Old 08-22-2010, 07:13 PM
tookrzy4u192's Avatar
I'm gonna look more into sound deadening products since I just realized my trunk rattles a lot..
tookrzy4u192 is offline
03-12-2020 12:06 AM
lrb6805
09-17-2015 04:49 PM
TheMafia
09-04-2015 08:26 AM
Quick Reply: Low cost sound deadening.
