bad head gasket, or waterpump
hey a friend of mine with a 99 had an overheating problem. she brought it to pep boys, and they replaced the thermostat and did a flush. the car still overheated.
so we replaced the thermostat again, and it overheated again. so i disassembled the old thermostat and tried to use blue devil's head gasket sealant. the car ran FINE. no overheating whatsoever.
so i go put yet another thermostat in, and guess what...it overheats again! so currently the car is running without a thermostat, not overheating. it doesnt leak coolant and there is no white smoke from the muffler. we replaced the radiator cap too. i went to drain the coolant from the car after it ran for almost an hour. as i removed the drain plug, the coolant was cool, then after draining for a few seconds, it was hot as it continued to drain out. i thought the radiator may be clogged, but when the thermostat is removed, coolant indeed runs thru the lower hose and the car runs fine..
does this sound like a headgasket, or waterpump problem?
Well, I dont see the reason for having gone through so many thermostats. If its still overheating after a tstat, its obviously something else.
First thing, how many miles on the 99? how long has she owned the car? has she ever had the waterpump replaced? is the coolant nice and green or brown?
Chances are its time to replace the waterpump but after all those overheats, I hope she pulled over and allowed the engine to cool down otherwise its gonna be a head gasket.
So here's what I say
1- As is, bleed the coolant system (I assume you know how)
2- if still over heating, inspect WP, if bad, replace.
3- Bleed
4- If still over heating, get a headgasket test to see if its blown
http://www.matcotools.com/Catalog/to...ype=T&cat=2477
3- Bleed
yeah they do when necessary
3- Bleed
3- Bleed
but with those miles, i'd say waterpump as well.
thanks to all of you, i will see what she wants to do and keep you posted if she wants to fix the car at all
03-12-2020 12:06 AM
The Wizard
24
10-01-2015 08:47 PM
