Just succesfully completed 1995-1998 swap
Old 08-07-2010, 05:35 AM
speedofsalt32's Avatar
So my rotted out Maxima is now in the junk yard stripped of any part worth anything. And my 1998 Is rippin' down the road. Had to switch the engine sensors, as the part number were all different even if they looked the same. The throttle body,AC compressor I switched alternators although i don't no if it was necessary and power steering pump intake heads block all the same except the fuel rail on the 98 had flat loops ant the end of the fuel rail instead of a inclined loop, my 1995 injectors work just fine Just was proud, thouhgt I would share. Love to hear about other people's swaps. nd what to do next when ya wanna go faster cheap
speedofsalt32 is offline
Old 08-07-2010, 05:53 AM
Kevlo for President
Kevlo911's Avatar
should of asked first, most of the stuff you swapped wasn't needed. the sensors on the 98 are likely updated ones so keep them just incase.
and congrats!
Kevlo911 is offline
Old 08-07-2010, 09:38 AM
NemesisMax's Avatar
Congrats on your successful engine swap.
I just had a mechanic do the same to my 95 Max and now I have the engine from a 98. Unfortunately I am having many problems. The engine can't run above 3,500 rpm. It hesitates whenever I hit the gas. I'm not sure what to do or who can help. Any suggestions are greatly appreciated.
NemesisMax is offline
Old 08-07-2010, 01:14 PM
NemesisMax's Avatar
Also, did you use the 95' engine computer or the 98' ?
Old 08-07-2010, 01:58 PM
"I'm just sayin'..."
nelledge's Avatar
Originally Posted by NemesisMax
...I just had a mechanic do the same... Unfortunately I am having many problems. The engine can't run above 3,500 rpm. ...I'm not sure what to do or who can help...
Shouldn't the mechanic help you? I'm confused.
nelledge is offline
Old 08-07-2010, 02:20 PM
DennisMik's Avatar
That's kinda my thinking too. Instead of scratching your hemmoroids, go give the mechanic grief and misery.
DennisMik is offline
Old 08-07-2010, 02:36 PM
NemesisMax's Avatar
He doesn't know why either guys. I guess I should have put that in my post.
Old 08-07-2010, 02:39 PM
NemesisMax's Avatar
He's doesn't know why this is happening. I can't get info that he doesn't have. I was hoping someone here might be willing to share their knowledge.
Old 08-07-2010, 02:41 PM
nelledge's Avatar
The problem with that is that the mechanic that replaced your engine knows an infinite amount more about your specific install than we possibly can. Your problem is just way too vague for a good hypothesis. Now, if you're looking for speculation and conjecture, I'm sure many will fill that need. Is there no other information you can give us?
nelledge is offline
Old 08-07-2010, 05:25 PM
NemesisMax's Avatar
HELP
I have a 95 Maxima and just had the engine replaced with a 98 Maxima's engine. Now the speedometer doesn't work and engine won't rev above 3,500rpm The 98 engine was in good shape and came from a Maxima that was totaled about 2 months ago. Unlike Speedofsalt32, I still have all of the old sensors and ECM from the 95. The "check engine" light is not on so it seems like the electronics are getting along, but the way it drives says otherwise. Does anyone know if it's the sensors and ECM need to be changed when swapping engines to a later year? Can the ECM be reprogrammed?
Old 08-07-2010, 05:51 PM
asand1's Avatar
Limp home mode. Did you check for codes? Sounds kinda like MAF but IDK.
asand1 is offline
Old 08-07-2010, 07:27 PM
FallenOne's Avatar
HELP
3 thing that it could be, or a combination.. Throttle Position Sensor, MAF, Tranny in Limp Home Mode.
FallenOne is offline
Old 08-07-2010, 09:02 PM
tyler5619's Avatar
speed sensor and maf. both would throw a CEL though. does your CEL illuminate when you turn the car on? (I.E. turn key to on position, but don't start the car)
if not, you also have a blown/disconnected bulb. if you went to a shady dude, he probably fcuked a bunch of siht up and pulled the bulb so you wouldn't blame him lol
tyler5619 is offline
Old 08-07-2010, 09:14 PM
DennisMik's Avatar
Is the CEL on? Have you checked the ECM for codes? Is the ECM the original or is it the one for the 98 engine?
Old 08-07-2010, 09:20 PM
TravisCadello's Avatar
also coolant temp sensor will make it go into limp mode.
TravisCadello is offline
Old 08-07-2010, 09:21 PM
tyler5619's Avatar
this?
HELP
Old 08-08-2010, 06:39 PM
Revo75's Avatar
Holy thread hijack batman!
lol good luck with the car doing a 3.5 swap soon
Revo75 is offline
Old 08-08-2010, 06:44 PM
NemesisMax's Avatar
I'm not sure what the CEL is and the ECM is the original from the 95
James92SE
142
01-02-2024 09:23 AM
03-12-2020 12:06 AM
Socalstillen
09-20-2015 11:46 PM
Bonka
09-14-2015 11:18 PM
I<3 A32's
09-10-2015 11:07 AM
Quick Reply: Just succesfully completed 1995-1998 swap
