96 engine harness and ecu on a 99
Old 08-06-2010, 06:59 PM
TurboA32's Avatar
im looking to do a engine harness swap on a 99 maxima with a 96 harness and ecu. has anybody done this swap before? and what did you have to do?
TurboA32 is offline
Old 08-06-2010, 08:31 PM
TurboA32's Avatar
and is there a way to disable the chip key
TurboA32 is offline
Old 08-07-2010, 05:11 AM
speedofsalt32's Avatar
How will this benifit you, i just swapped out a 1995 into a 1998 the '95 system, although '95 was obd2. The 1995-1996 are visually the same. I would assume their emissions sensors are as well. But you're gonna have a different set up here. I switched out my throttle body and all the sensors were diff part numbers even if they looked the same. also switched out the vaccume line stuff and im sure other things i don't remeber. as for phisically pluggin in under the hood. Take out you radio clutste and **** there will be two small dizzys(harness plugs) and your main dizzy. those should all physically fit like the radio but i don't know why you wanna do this but long story short you'll be missing plugs underhood wise
speedofsalt32 is offline
Old 08-07-2010, 06:03 AM
Kevlo for President
Kevlo911's Avatar
If you swap the harness, you might as well look into swapping the ignition wires too so that way all the 99 stuff is bypassed.
Swapping the harness should work, but the nats gets a signal from the 99ecu so you need to bypass that. we had a thread on it a while back, search for it .
Kevlo911 is offline
Old 08-07-2010, 09:33 AM
TurboA32's Avatar
i couldnt find anything do you have a link for me
TurboA32 is offline
Old 08-07-2010, 09:57 AM
TurboA32's Avatar
well i want to disabel theft system and use the 96 harness with the ecu because thats what i have and i want to use the jwt ecu
TurboA32 is offline
Old 08-07-2010, 01:39 PM
NemesisMax's Avatar
HELP
I have a 95 Maxima and just had the engine replaced with a 98 Maxima's engine. Now the speedometer doesn't work and engine won't rev above 3,500rpm The 98 engine was in good shape and came from a Maxima that was totalled about 2 months ago. Does this sound like an engine computer problem?
NemesisMax is offline
Old 08-07-2010, 05:33 PM
NemesisMax's Avatar
Is it possible to do just the ECU and not the entire harness?
Old 08-07-2010, 06:47 PM
TurboA32's Avatar
do you have any codes?
TurboA32 is offline
Old 08-07-2010, 06:49 PM
TurboA32's Avatar
and it doesnt matter which year you got it from as long as you keep everything 95 then you are good.
TurboA32 is offline
Old 08-09-2010, 03:26 AM
99greddymax's Avatar
in my days as a lurkers.. i read that people swapped in 96 jwt ecu's in their 99 maxies. im sure it can be done, just need to rewire it some?
99greddymax is offline
derekinthez
11-13-2022 04:00 PM
JoshG
09-05-2015 10:10 PM
Quick Reply: 96 engine harness and ecu on a 99
