Mod Sugestions?
Mod Sugestions?
So, here's the deal. I've got a few mods done to my Max and I've got a MEVI sitting in my garage waiting to be put on. I'm looking for a little advice on what performance mods I should do while I've got the upper intake manifold off. I would like to do anything I should all at once. For example, thermal phenolic intake spacer kit, or bigger injectors? If you can, let me know what I should do, and how it will help me out.
Current Performance Mods:
Injen CAI, Clutchmasters FX300 clutch, Clutchmasters lightweight flywheel, Stillen Y-pipe, Stillen B-pipe, Stillen Muffler, Stillen FSTB, Stillen RSTB, Stillen RSB, Stillen STS, ebay high-flow cat (test pipe), Tokico Illumina Struts and Springs, and I think thats about all that might be relevant.
I have some pretty harsh hesitation sometimes so I plan on doing a lot of maintenance while I have the thing torn apart (cleaning the IACV, EGR, MAF, throttle body, replacing the PCV, and using Sea Foam). My roommate knows Jim Wolf so I will be taking my ECU to him to have it reprogrammed. I am also going to get my car fully tuned once I have everything done, so I wanna make sure I have all performance mods done that I should. Any advice or opinions are fully appreciated! Thanks ahead of time!
I made a video with a friend's max of how to do all that maintenence and will make another one on mine for all of you out there. Anyone else have suggestions on mods that should be done at the same time?
Clean those GND wires. I replaced the main battery GND and the alternator GND with hand made wires. I cleaned and replaced the crimp connectors on the GNDs for the relay boxes. I added a GND straight from the NEG terminal to the transaxle. I added a few from the engine to various chassis mounts.
The running volatge jumped from 13.5V to 14.4V.
I have, but I've also heard some negatives about these. What do you guys think? Anyone else care to weigh in?
Also, anyone think I should do bigger injectors? Or is that only really beneficial if you're FI? Anything else?
I was a car audio supervisor for like 6 years and I've got a toolbox full of spare 4 gauge wire and 4 gauge ring connectors. I will be cleaning the factory GND points and adding new GND cables, but I think I might not do this immediately. But, I definately will before I have it tuned! Thanks for the advice!
Bigger injectors for either 3.5 swap. Not sure u need for FI.
Pulleys are only really worth it if u got the lightweight flywheel too.
I agree with the Spacer Kit. I read alot of threads about them last night before I ordered to to put on when I do my MEVI that I ordered last night. Maybe replace spark plug grommets while your there because thats the original reason im taking the UIM off.
If you do the 3.5 swap, why not use the 3.5 injectors?
Honestly, there is no need for larger injectors unless your currently maxing out your stock ones. Which isnt going to happen on an NA setup. Even mildly boosted vehicles can run stock sized injectors.
To the OP, Im a bit confused when you say JWT will be reprogramming the ECU and then you plan on having a tune done?
But if you go JWT, then that is a different story...
Originally Posted by EVERYONE
You don't need bigger injectors!
Anyone have an opinion on cams or anything else I should consider? I know the MEVI is not that major of a project, I just wanna knock it all out at once so I can get the most benefit out of the tune.
So, this is what your going to do...
1. Valve Cover Gaskets
2. CLEAN CLEAN CLEAN! EGR, IACV, Manifold's,MAF, TB!
3. Re Ground!
4. Spark Plugs
5. NWP Spacer's!
6. JWT ECU!
Don't bother screwing with the Injectors or Anything related. Our Injectors are fine for anything but FI!
3. Re Ground!
4. Spark Plugs
5. NWP Spacer's!
6. JWT ECU!
zzznightmarezz
09-21-2015 06:32 PM
