No good write ups on RMS?
Old 07-05-2010, 10:10 PM
speedofsalt32's Avatar
I was surprised not the see a good one, being as common as it is any one have any pics when they were doing one?
speedofsalt32 is offline
Old 07-05-2010, 10:43 PM
EsQueue's Avatar
I read this 3 times and still don't have a clue WTF you are typing about. Maybe someone else will chime in.
EsQueue is offline
Old 07-05-2010, 10:47 PM
perkman87's Avatar
I think the Newb means Rear mount Turbo Set ups.
perkman87 is offline
Old 07-05-2010, 11:25 PM
schmellyfart's Avatar
Rear main seal?
schmellyfart is offline
Old 07-05-2010, 11:26 PM
cartman854's Avatar
root mean square?
cartman854 is offline
Old 07-05-2010, 11:31 PM
Blackwind's Avatar
Roast Mamwich Sandwich?
Blackwind is offline
Old 07-06-2010, 12:25 AM
96i30azn's Avatar
RMS
Let's see what we have here:
-Russian Musical Society
-Raytheon Missile Systems
-Royal Mail Service
-Royal Medical Society
-Railway Mail Service
Things relating to Maximas or automobiles:
96i30azn is offline
Old 07-06-2010, 05:27 AM
max ride 41's Avatar
yo salty, until you reply op are gonna bust some shoes on u. if your talkin rear main seal, then i would'nt touch it unless its leaking really bad cause you gotta pull the trans and it aint all that easy of a job bro. i've never seen a write up on it, and my local trans shop did'nt even replace it when i had a trans swap done. ( even tho i told them to change it )
max ride 41 is offline
Old 07-06-2010, 05:35 AM
95Maxed's Avatar
What if he's just messin with us and it means nothing?
95Maxed is offline
Old 07-06-2010, 05:52 AM
Black Lion
maxprivate's Avatar
I have a small leak on my rear main seal, my mechanic told me not to touch it unless it gets real bad because its an expensive job and a pain in the ****.
maxprivate is offline
Old 07-06-2010, 06:16 AM
locknuts27's Avatar
RMS, as in root mean squared? If you truly want to find out about continuous power, then just multiply .707 to peak power or max power. Then you have the answer!
locknuts27 is offline
Old 07-06-2010, 08:33 AM
Trini Boom's Avatar
Listen, I have took my tranny apart and let me assure you, it is not your rear main seal. It is the upper oil pan seal that is right below your RMS seal. That is what is leaking and the proper way to fix it is to take off the upper oil pan. You do not need to remove the tranny. I also researched it on here and did a shortcut which I fould where someone took off the tranny and forced in a new pan seal which only worked for a few days. Ask anyone that has done this job themselves and not a shop and they will tell you its the upper oil pan seal and not the RMS.
Trini Boom is offline
The Frye
09-02-2021 11:03 AM
MaxLife17
06-27-2019 01:37 PM
dvcamp
09-18-2015 10:17 AM
MaxLife17
09-08-2015 02:36 PM
sdotcarter
09-02-2015 09:53 PM
Quick Reply: No good write ups on RMS?
