Never buy GSP axles !!!
installed a pair new 5 months ago, driver side started making click sound a month ago. Went back to advanced auto parts and got another brand new one. It's making click sound immediately after installation! Now the passenger side started making click sounds.
Never buy GSP axles. The limited lifetime replacement warranty just means "lifetime waste of money on labor fee for replacing".
I have had the same experience with these GSP axles. I did an engine swap and replaced lots of stuff including the axles. My driver side axel only lasted like 2k miles and started flinging grease. Passenger side was done three days ago. Same problem, the boot split @ the seam and the grease all spun out. I do the work myself but it always seems like i need an alighnment after I swap an axel. So I guess after the $160 for the junk GSP axles and replacing both I still get to cough up more $ for another alighnment. I guess the raxel axels i've been reading about would be a worthy investment.
I've gone though about 11 or 12 driver side Duracrap "new" axles in 2 years... and its currently clicking but that one was my fault for accidently pulling and "dislocating" it. Didnt feel like pulling the boot and readjusting so I just banged the **** out of it knowing I'll be replacing it once again shortly. Ugh
So whats the recommended or preferred axle for the 4th gen max..
I was just about to pull the trigger on the GSP's for 70$ a side or so..
Someone mentioned raxles on another thread but i think they are way more expensive! Over a hundred each i heard but i dont have an exact price yet.
Any honorable mentions in the axle world? with a good price point too...??
(+ liftetime warranty, but i dont want to be changing axles every 3 months either)
i had a pair in my 5th gen for 6 months before i sold it and havent had a problem with them, like the other op stated its hit or miss with them, maybe you should contact gsp if you feel like youre being screwed?
hope i hit and not miss
just had a guy put on two front gsp axles for 100 bucks....he didn't do half of the stuff he was supposed to but anyways i hope i hit with these and not miss....I'll report back if they break soon...if they do I'll be going with the raxles better start saving though at 140 a piece
I've gone through about 7 sets of these axles myself. One of which lasted a whopping 5 days. But I figure that I'm so low anyways that no matter what brand I get, i'll go through them in no time.
The main problem I've experienced with these is they make the absolute worst thumping sound/feeling when moving off from a low speed. You can feel it coming from the passanger side. I thought this was from being so low too. But a friend of mine is just about as low as me experienced the same thing with these axles. When he switched to another brand it went away and has been good for months now. I'm gonna try another brand and see if it makes a difference.
Great, look like I should get another axle as a spare.
I put Napa axles in my old 96 back before I even had real tools. Never one issue over 5 or so years and Id guess 70k miles. Its still in the family and I have not heard about it needing axles yet. It must have 220-250k by now.
From what I have read(not only in this thread) and my experience, GSP is the first brand you should avoid.
Raxle? I heard a lot, but it's much pricey. a pair would cost $400, including shipping.
Napa axle seems to have reputation here. but new will cost $100 per side. But I think it's worth.
So, if you want to keep you car for more than 5 years, maybe you should go for raxle. if just for 2-3 years, NAPA is a good choice.
Forgot to mention, I recently replaced my driver side axle in April with a Napa one...so far I would've gone through 2 duracrap ones so I can say it seems to be a quality axle...
I installed these axles on both sides of my car about 2 years ago... I put approx 20,000 miles on them and the driver side boot ripped recently. I took the axle out and back to advance, they gave me a new one, and told me that my motor and tranny mounts could be causing the boot to tear....has anyone else heard this from the people at Advance and is it possible that it is my mounts?
If the axle boot got torn, chances are temperature is the case. Extreme heat could cause dry rot while extreme cold could simply harden the rubber/plastic and over time after having both of these temps, it'll eventually fail. Perhaps a hint of vinyl/leather/dash conditioner might extend the life if that was the case.
Bad mounts AND other suspension problems could cause the axle to go bad but I doubt the boot would go bad before the axle if that were the case.
I've got GSP axles with about 5k miles. I've been really trying to figure out where the hell that thumping/clicking noise was coming from with initial acceleration. So it's the axle huh?
If it makes sense... I can duplicate the noise by putting it in gear without pressing on the brake but engaging the parking brake so I don't move. If I'm pressing on the brakes, no noise.
At any rate, it sounds bad, like a suspension component is loose, but I can't find anything loose.
I asked about refurbished axles when I was changing mine, and heard nothing but bad things, just go with new ones.
I'll try to make it short....installed two Napa axles in August, and had to remove them to do a clutch and rear main seal job. Passenger side came out just fine, driver side was stuck and would not come out. Sent the trans and axle off to the trans shop and they had to disassemble the trans to get it out. Apparently, the C retaining clip was too big and got lodged in the transmission. $325 transmission bill later, never buying Napa axles again. The majority of them are likely good quality. I ordered Raxles to replace them.
Marty and Raxles are the best way to go. Sure you can do the job cheaper with AZ or DAP but you'll end taking them back out and redoing the job again. With Raxles you'll do the job once and have axles and boots that will stand the test of time. Besides, why would you want a cheap part between your powerplant and the where the rubber meets the road? http://www.raxles.com/
Happy and Safe New Year, Mark V.
sucks that a bunch of people in this old *** thread had problems with GSP, i havent had any issues yet with mine, im lowered on coilovers also. and i rarely ever get them returned either (i work at advance)
Thanks for the help, but that is the usual method when there is not a C retaining clip slipped out of the axle groove and lodged between the axle spline and gear. The only way to remove the axle without damaging the transmission is to disassemble and pull the C clip out with some needle nose pliers. Believe me, I tried the old crowbar method first.
ya i recently just went to advanced and got a gsp axle... so thank you advance for f'ing my car up ... def gonna go with napa or raxles now. i will never do that bs lifetime warrenty crap again. you get what you pay for.
The other axles that Advance sells seem to work pretty well. Fenco is the brand. They're cheaper and supposed to be remanufactured, but they're apparently generally low on cores and end up shipping new ones instead. Had mine on the left for over a year now, still going strong.
Go with Raxles or OEM replacements.
Have had a 0.5" ~ 1.5" drop over the years and had the Raxles on since '06 with about 30K miles on them now. Around 2000 miles were on road courses with r-compunds, auto-x, and 1/4 mile passes. ZERO problems with these axles so far and the dust boots still look good.
Bumping this to continue keeping people away from GSP axles. I installed a pair last September and both driver side and passenger side CV boots are spitting grease all over my wheel wells already. I almost got a year out of them! I'm buying Raxles to replace them. Oh yeah, I'm riding on a bone-stock suspension setup.
