Cap/Hub does not fit on rim
Old 06-29-2010, 04:51 PM
delacruz_17's Avatar
I installed my rims and the rear cap does not fit.
Any ideas?
EDIT: Rims are from a 2004 G35 Infiniti.
delacruz_17 is offline
Old 06-29-2010, 05:03 PM
Gram Lights addict
QT1 5MT AE's Avatar
take the hub cap off...
QT1 5MT AE is offline
Old 06-29-2010, 05:04 PM
looks ugly without it
Old 06-29-2010, 06:36 PM
Fasteddie01's Avatar
Yaas - I had a similar problem when I put rims from a Mazda on. The hub dust cap on the car is too big for the hole in the rim, right ? I just beat the hll out of the cap till it fit. Later when I did brakes, i just left it off ... that was 2 years ago. Eventually it'll f--- the bearings, but modern bearings are 'sealed' so it'll be a long time unless I go off-road.
I suggest you pull the caps and forget it. Maybe someone here will come up with a part number that'll fit under the rim cap, but the dealer wouldn't try to check ... no measurements on his computer list.
Good luck if you try to find something.
Fasteddie01 is offline
Old 06-29-2010, 06:37 PM
PS - I tried back then for assistance here on the org and got nada.
Bueno suerte.
Old 06-29-2010, 06:46 PM
thanks for your input! I will try to beat the heck out of that piece and make it fit.
Old 06-30-2010, 09:12 PM
1995maximagxe's Avatar
I gave up on my caps. had the same problem looked and looked.
1995maximagxe is offline
Old 07-02-2010, 10:59 AM
Kretzmech's Avatar
to solve this you can hammer them flat, I have done this, it gives that space so the center caps will fit
Kretzmech is offline
Old 07-02-2010, 11:03 AM
will try this weekend
Old 07-02-2010, 10:50 PM
Kretzmech's Avatar
you shouldnt take them off to hammer though, keep em on of they might not fit back on ;]
Old 07-03-2010, 12:52 AM
Maximum-Maxima's Avatar
I think he is trying to put the stock maxima center cap on the G wheels in which case that is not possible. If you want to keep a nissan center cap on your wheels try some 2002+ nissan center caps they are smaller diameter.
Maximum-Maxima is offline
04-16-2020 05:15 AM
coolsun
Wheels/Tires
11-13-2016 05:01 PM
Fbana41
08-29-2016 12:18 PM
trsandrew
10-25-2015 02:47 PM
Pied
09-26-2015 03:29 PM
Quick Reply: Cap/Hub does not fit on rim
