HELP! Clutch problem...where to start
Old 06-29-2010, 02:46 PM
eta_vu's Avatar
Hey fellow maxima enthusiast,
I had the weirdest thing happen to me about 2 weeks ago. I was driving my car and went to exit. As I was approaching the red light I began to push in my clutch, about 1/4 of the way in it seemed to lose pressure (no resistance) and I then couldn't put my car into gear.
I managed to drive it home in 4th gear the whole time. I got home, turned off the engine and restarted it. Clutch was fine. I haven't driven it since, it's sitting in my drive way for fear that it will stall out on me again during rush hour or something.
Sorry for the lack of details but I have no idea what's going on. Please help me!
eta_vu is offline
Old 06-29-2010, 03:12 PM
Kevlo for President
Kevlo911's Avatar
Check to see if there is enough fluid in the master cyl. Check for leaks.
Might have to refurb/replace the master and/or slave cyl
Kevlo911 is offline
Old 06-29-2010, 08:48 PM
eta_vu's Avatar
Where would the master and slave cylinder be located? could you possibly direct me to some info??? Thanks for your reply
eta_vu is offline
Old 06-30-2010, 01:35 AM
ColombianMax's Avatar
Clutch master cylinder is where you put the clutch fluid (brake fluid) its located on the driver side firewall next to the brake master cylinder but slightly lower and more towards the fender and a bit more hidden. Make sure its filled to the max line.
Clutch Slave cylinder is kind of located where the engine and trans mate, I'd say is somewhat 12to 18 inches to the left of where the relay box in front of the battery is located.
Id post pictures but dont have any at the moment. Have you checked the FSM?
ColombianMax is offline
Old 06-30-2010, 06:38 AM
Kevlo for President
Kevlo911's Avatar
http://www.nicoclub.com/FSM/maxima/
They should be in MT
If you go to autozone.com they have repair guides as well, they are very helpful. Just register and it's good to go
Kevlo911 is offline
03-12-2020 12:06 AM
BkGreen97
04-02-2016 05:47 AM
97_GXE
09-15-2015 06:47 AM
QueensMAX
09-15-2015 04:14 AM
trungg86
09-04-2015 04:58 AM
Quick Reply: HELP! Clutch problem...where to start
