oil leak
#41
So I just pulled into my driveway, not in my car, and noticed a small puddle under the front passenger side. It seems to be oil, but not positive. I stuck my hand under there and took a few pics with my cell phone, sorry for the bad quality. But it looks like the leak is coming from the oil pan. It almost seems like a rock is wedged in there too. would that cause a leak? Let me know what you think. I wouldn't try to fix this myself, so any guess as to what I might pay would be a huge help.
#42
Hello All,
I am also trying to figure out the source of a leak. So far, I have replaced the front and rear valve covers and all of the seals in the engine (oil pans, front, rear etc). I have spent over $600 (not too $$$, I know, but the darn thing still drips!).
If I run the car on the highway for 30 minutes, I will get about 20 drops of oil dropping approximately 18-24 inches in from the front bumper almost directly in the middle, slighlty dripping towards the passengers side. If I just turn the car on for a few minutes, it will drip less (maybe 5 drops, same location). The drops are within a few inches of each other.
Our mechanic has suggested that it may be 1 or 2 of the pistons and the engine would need to go out to a machine shop.
Does this sound correct or are there other more obvious suspects?
Thanks to anyone who responds!
#43
i had the same oil problems with mine except mine leaked from the lower and upper oil pan. the 4th and 5th gen 3.0 all have a 2 piece oil pan and on the upper pan there is the front and rear crankshaft seal that can leak oil. but i always tighten my valve cover gaskets every 10 thousand miles or so just a quick snug always helps
#44
Hello All,
#45
Thanks. I have been reading and I suspect now that it may be a problem with the oil pan sealing. It's very frustrating! The piston thing sounds strange to me. That seems like a lot of oil for a piston.
Is the front or rear pan usually the source? I had all the seals done last week, so apparently something still isn't tight! Forgot to mention in my first post that this is a 98 GLE.
#46
Hello All,
#47
#49
once you have removed the upper oil pan you will have this. The section outlined in red is your front and rear crankshaft seals. the area outlined in blue is where permatex is required. also when installing the seals lay a bead of permatex over the end of the seals to make sure they seal. also if the area isnt clean it will not seal properly. sorry for the bad editing was trying to hurry
#50
have you checked the seal on your dip stick. if it is split or not all the way in the dip stick hole it could cause i minor leak. makes since the more you run the more it drips. it wil take a while for the oil pressure to push oil up the tube. I only know this because mine was split and it leaked minor but still leaked and did you replace the front andd rear crank seals on the upper oil pan??
I just checked the dip stick, but it's fine. Good tip and it would have been an easy fix if that was it! One clue though, the oil is filled to the very top due to the fact that we added a bottle of stop leak before we did all the seal work. Maybe the oil is too full and contributing to the problem we have here?
#51
Thanks! I thought your editing was great. Very self-explanatory for someone who does not understand motors well. I can see how this would be a real pain to seal. Tomorrow I will get under the car in the daylight and see if I can see the leak from the pan, now that I know what I am looking for.
I really appreciate your help on this. My daughter is coming in for Thanksgiving this week and I really want to have the car ready for her to take back to school.
#53
also if you buy a new gasket for the lower oil pan do not add permatex with the gasket the oil will eat around the permatex and leak. you can use a sticky substance i think its called indian gasket it is a spray to hold the gasket in place while you reassemble it. and it will not effect the performance of the oil pan gasket
#54
#55
We got underneath the car and it's leaking exactly where you said it would be- the upper pan. The mechanic used gray silicone, so it makes perfect sense why the leak got progressively worse in a few days time. Well, I'm bringing him the permatex tonight and will try to find the Indian gasket spray as well. I really can't complain since he did the job so reasonably. I'm just glad you were around to advise on this seal problem. Will update in a day or 2. Thanks!
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
