Car hesitated to turn over!!
Old 06-11-2010, 02:08 PM
canIlive's Avatar
I drove to a cleaners, parked my car, picked up my clothes and came back. I tried to turn on the car and it kept cranking but would not turn over! I sat and tried for about 10 minutes and it finally turned over (Lately, it hesitates for about 2-3 seconds then turns over). Anyway, I drove for about 15 minutes but then at a red light, it shut off. I quickly put it in park and cranked it and it turned over. What the hell is going on? Is it my starter? I just replaced my alternator about 2 months ago. Help!!
canIlive is offline
Old 06-11-2010, 02:39 PM
bkortee's Avatar
Welcome to the 4th gen maxima forums. Just about all of us have trouble starting the max. As far as it shutting off, I have no idea. Pop the hood and check it out.
bkortee is offline
Old 06-11-2010, 02:42 PM
95Maxed's Avatar
Ummm... Ive got no trouble starting mine, ever *knock on wood*
95Maxed is offline
Old 06-11-2010, 03:26 PM
sgtboehn's Avatar
Well now......arent you special!! LOL
sgtboehn is offline
Old 06-11-2010, 05:12 PM
canIlive's Avatar
anyone else have actual ideas as to how I can fix this problem?
canIlive is offline
Old 06-11-2010, 05:14 PM
LeFrank99's Avatar
could be a lot of things, my first guess would be the fuel pump or maybe the fuel filter
is your check engine light on? if so check the code
LeFrank99 is offline
Old 06-11-2010, 06:18 PM
shadetreemech77's Avatar
Go to a parts store and have your battery tested. I had a bad battery that caused all sorts of problems. Nearly made the car undrivable. Replaced the battery and it was good as new.
shadetreemech77 is offline
Old 06-11-2010, 08:28 PM
sgtboehn's Avatar
Best thing to do is start at the beginning, do a search in the forums there are plenty of write ups and how to's on diagnosing your problem. Alot of people have had this problem to include myself. Unfortunately it could be alot of things. Sensors, grounds, ignition, starter, battery, loose connections I could go on and on. Have you done any work under the hood lately? I have learned that when a problem occurs, it usually has alot to do with previous work, as far as a ground not being tightened down properly or a sensor not properly connected. Start with the easiest and most common and least expensive, that way your not kicking your self in the *** in the end! Good luck and keep us updated on your progress, the forums and people who frequent them for the most part are pretty helpful!
sgtboehn is offline
Lakersallday24
06-16-2019 01:35 AM
beboski
08-16-2015 05:23 PM
acw
08-07-2015 04:20 PM
egali045
08-05-2015 09:02 AM
Quick Reply: Car hesitated to turn over!!
