Starter help
Old 05-24-2010, 07:23 AM
VQrebuild96's Avatar
Starter help
Hi whenever i turn my key all the way over nothing happens. I do not hear a sound. The starter had been clicking before and would eventually start but now not even a click. So i jumped the solenoid with a screw driver and heard it come on. So i thought it was the starter. I swaped it out with a use starter that i do not know if its good or not but its doing the same thing. The solenoid spins but it won't start. I checked the 7.5a fuse and it was good. Any ideas? Thanks
VQrebuild96 is offline
Old 05-24-2010, 07:31 AM
cashoit's Avatar
New starter my man
cashoit is offline
Old 05-24-2010, 08:32 AM
stamar's Avatar
get the starter tested for free at an auto part store. kragen autozone whatever
i can usually tell without taking it to a machine
plug the thing in then use a jumper cable to give it juice.
youll see if its spinning fast enough.
My starter went out but the solenoid was still working fine. so remember just the solenoid function doesnt matter
if the starter works then it could be a fuse, describe all the lights that are working when you turn on the key
It could be the ignition.
stamar is offline
Old 05-24-2010, 11:58 AM
Ok so i got the starter tested and it is good. What do i check from here? My battery is good.
Old 05-24-2010, 12:09 PM
haydeno's Avatar
Have you checked grounds for corrosion. I had similar problem but not as bad( would start eventually), found ground rusted to hell, cleaned and added another run of 4ga and all good now.
haydeno is offline
Old 05-24-2010, 12:25 PM
My brother told me to change the clutch pedal sensor should i check anything else?
The starter does not tick or anything. My grounds may be dirty with oil and grease but i think its okay because I'm not even getting a tick.
Old 05-24-2010, 02:01 PM
Clutch sensor swapped, still not starting. ???
Old 05-24-2010, 02:43 PM
stamar's Avatar
ok detach it from the engine, leaving it plugged in
does it make any sound at all when you turn the key?
ok what are the lights that come on, do the gauges work?
ok, underdash drivers side small fuses, and then check the big fuses up in the engine bay, check that big giant 70 amp one.
Ok well you CAN leave the plug in but detach the wire from the starter, get jumper cables straight from the battery to it. If it starts then its the wire from the battery to the starter.
definitely examine all the things that still function when you turn the key.
am i right when you say that you dont hear a solenoid, or a attempt to crank, neither right?
stamar is offline
Old 05-24-2010, 02:58 PM
Justaguy's Avatar
Funny, I'm seeing the exact same thing..My starter was replaced 3 months ago.
I turn the key on, I see the dash lights go on, but no ticking, no sound..nothing..sometimes if I just hold it for 2-3 seconds it kicks in and the car immediately starts (no whinning or cranking heard). Must be a bad connection somewhere.
Justaguy is offline
Old 05-24-2010, 03:01 PM
Jumped the solenoid with a screw driver and all i hear is a whining like the starter is spinning but not turning over the engine? Why is this?
Old 05-24-2010, 03:12 PM
I am getting no power when i turn the key, I checked it with a multimeter. I Short out the solenoid with a screw driver should I try another method?
Old 05-24-2010, 03:36 PM
WhiteMaxima9600's Avatar
IGNITION SWITCH, 30 BUCKS AT AUTOZONE. Had the same problem and blew $200 on starters i didnt even need! Simple install, check pmohr's vids on here for simple how-to video.
WhiteMaxima9600 is offline
Old 05-24-2010, 05:22 PM
It was just that the clutch was not hitting the sensor...lol it was a little rubber piece.
Old 06-04-2010, 10:06 AM
LeFrank99's Avatar
Hi , since i can't start a new thread due to me being new, thought i'd ask here..
I changed the starter last year and once in a while , while the car cranks, the starter seems to jam for half a sec; it cranks then u hear a "TAK" then keeps on crannkig then starts. All that in in maybe 2 sec, the car doeesn't have a hard time to start.
Thx for any info u can give.
LeFrank99 is offline
Old 06-04-2010, 11:45 AM
EsQueue's Avatar
Either the starter is going bad or it itn't getting sufficient amperage. Check all of your grounds for corosion and make sure everything is tight.
EsQueue is offline
Old 06-04-2010, 01:09 PM
stamar's Avatar
what you described sounds like a burr in the teeth of the starter. it could go on like that without getting worse until the end of time there is no real fix other than replacing it, or the flywheel that causes it.
stamar is offline
Old 06-05-2010, 07:51 AM
LeFrank99's Avatar
yeah I thought about the flywheel hopefully it's ok..
I'll check the amps this w-e.. Thank you for the input
mikeg75
11-30-2015 05:12 PM
Excalibur23
10-13-2015 04:33 PM
maxima297
09-30-2015 03:32 PM
msellas
09-23-2015 09:16 PM
homewrecker
09-23-2015 03:41 AM
Quick Reply: Starter help
