Replace outer tie rod How to
Old 05-12-2010, 11:13 AM
holymoly's Avatar
yes yes, I searched and I searched, but no definitive step by step with pictures, I NEED PICTURES, or I am at the mercy of my shop.
My parts store informed it should take only 10 minutes if it isn't seized or warm up my blow torch.
Anyone have have something?
holymoly is offline
Old 05-12-2010, 02:51 PM
luke95gxe's Avatar
very easy jobtake tire off get tie rod seperator 10 buck at adavnce take cotter pin out 19mm nut take off put tie rod seperator on hit it with hammer a few times tak lock nut loose count how many turn it takes to get off install in reverse order then get an alighnment
luke95gxe is offline
Old 05-12-2010, 06:43 PM
f550maranello2's Avatar
maybe you shouldn't be doing that if you need pics... sorry but its true..
take the wheel off and you should see what you need to do..
f550maranello2 is offline
Old 05-12-2010, 09:13 PM
Snypa's Avatar
http://www.youtube.com/watch?v=jFXfcM325ss
Snypa is offline
Old 05-13-2010, 07:27 AM
holymoly's Avatar
great video. not sure I need tie rod separator, but will get one.
My 98 maxima has orginal tie rod. If seized have PB Blaster, but if stuck would a blow torch do the trick?
holymoly is offline
Old 05-13-2010, 01:31 PM
Trini Boom's Avatar
Rent the tie rod separator from Autozone. Blow Torch is kinda overkill just for an outer tie rod. Once you you hammer it in, it will come up with ease.
Trini Boom is offline
Old 05-13-2010, 01:50 PM
holymoly's Avatar
Parts Source asked what size of tie rod separator tool.
I am having a hell of a time loosening the bolt on the inner tie rod.
From the videos I gather counter-clockwise direction is with wrench going downwards that is facing the whole assembly.
holymoly is offline
Old 05-13-2010, 02:04 PM
I'm nutty for Nissans
JSutter's Avatar
Dont use a separator. Just remove the castle nutt and hit the steering knuckle, where the tie rod bolts to, with a BFH.
JSutter is offline
Old 05-13-2010, 02:16 PM
ATTappman's Avatar
The distance between the two forks should be at least 22mm, or about 7/8".
ATTappman is offline
Old 05-13-2010, 02:27 PM
holymoly's Avatar
did it all and w/o that tool. All I need is an alignment in the morning,
Can't believe my mechanic wanted to charge $80 to change it.
Another DIY job.
Thanks for the advice.
holymoly is offline
Old 05-13-2010, 07:20 PM
ColombianMax's Avatar
Here dude... I made a write up a few years ago. Its nearly the same http://forums.maxima.org/3rd-generat...t-writeup.html
ColombianMax is offline
Old 05-13-2010, 07:21 PM
dang I'm late lol
Old 05-17-2010, 10:01 AM
dkillahster's Avatar
Originally Posted by ColombianMax
dang I'm late lol
lol
well, at least it will help him
dkillahster is offline
6spd4dsc
03-04-2016 05:19 PM
PH98I30
26
10-12-2015 05:01 AM
dvcamp
09-18-2015 10:17 AM
dcam0326
09-08-2015 11:02 PM
Maxima30
09-07-2015 06:13 PM
Quick Reply: Replace outer tie rod How to
