Sunroof not working!
Old 05-14-2010, 03:23 PM
sgtboehn's Avatar
Having a little problem locating the fuse and relay for the sunroof, checked the fuse box and under the hood, what is this fuse marked as? And before i start tearing the interior apart can somebody point me in the right direction to locate the relay? Checked the "how to's" and the links were not working. And of course my Tech manual, tells you it has the fuse and relay...but unfortunately does not tell you where??
Just want to rule out the obvious before i consider rebuilding the sunroof!
Appreciate it!
sgtboehn is offline
Old 05-16-2010, 01:20 PM
sgtboehn's Avatar
Nobody?
sgtboehn is offline
Old 05-16-2010, 06:34 PM
jovani4183's Avatar
Did You check the sunroof switch? I have a perfectly working sunroof switch.
jovani4183 is offline
Old 05-16-2010, 08:34 PM
Nopike's Avatar
If your windows, door locks and cruise are fine than it's not a fuse problem because the fuses also protect those circuits. If in addition to the sunroof you also have a problem with those items than it probably is a blown fuse. There is a 7.5 amp fuse #12 under the dash drivers side fuse box and a fusible link "f" 30 Amps under the hood by the battery. The sunroof relay is located behind the drivers side kick panel.
Nopike is offline
Old 05-17-2010, 06:16 AM
Nopike's Avatar
If you want to download a service manual, go here - http://www.nicoclub.com/FSM/maxima/
Nopike is offline
Old 05-17-2010, 01:54 PM
sgtboehn's Avatar
Thanks for the info, my door locks and such are working fine, I have not checked the switch yet, and I will also check the relay, just wasnt too sure where it was located. thanks again, will let you know!
sgtboehn is offline
maxinout93
10-27-2015 01:29 PM
jerrod99_se-l
08-27-2015 08:27 PM
BobMax
08-21-2015 07:38 AM
BobMax
08-15-2015 12:35 PM
kenc15
08-05-2015 08:29 AM
Quick Reply: Sunroof not working!
