Help with OOIV swap?
Today I decided to do my OOVI swap I called it quits for the night but, so far I have got the 2000 LIM injectors and fuel rail on and started removing EGR so I'm looking for link or how to tips on installing injector pig tails on OOIV swap any help greatly appreciated thanks. I'll check back in the morning if any one could chime in thanks.
theres two wires on each clip....just match up the reds together and whatever other colors are there and you should be straight. if the colors dont match like that, just make sure the new clips wire in the same way the old ones come off. very simple
Ok I have a few questions, first question I need some help on is when I ran my AFC to the vias I connected red wire on vias to pink wire on my AFC, brown wire to a ground and do I supply vacuum to the vias yes or no? Second question can any one give me some info. on settings that I could set my AFC at until I get it tuned later this week. Third question, I have a check engine light on and the code is p1105 malfunction control fuel air metering, thats what my scanner said when I scanned it 20mts ago. Any help will be greatly appreciated
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
HerpDerp1919
09-29-2015 02:02 PM
