The LED Light Picture Thread -Interior-
Old 04-05-2010, 11:15 AM
aackshun's Avatar
Post up your LED'd interior photos, descriptions what was used or brought would be appreciated too!!!
I'll start things off:
@ Night w/ my Blackberry
Just used 3mm red LEDs from radio shack with no resistor and I did not cut the little nipple under each switch.
GO!
aackshun is offline
Old 04-05-2010, 02:24 PM
schmellyfart's Avatar
I'm currently redoing it with either 4 or 2 LEDs in each socket. One 3mm LED just doesnt do the job.
schmellyfart is offline
Old 04-05-2010, 03:01 PM
Pullin3RD's Avatar
Both pieces are nice.
For the driver side master window Aackshun if you can please describe the paint you used for your interior pieces..( Looks real clean ) What kind of prep you did? And whats the quality of the paint work. You know, for example how you see some people paint their door panels and such.. and paint is easy to chip off, possibly get on to your clothes etc.. ya know.
thanks guys keep it coming.
Pullin3RD is offline
Old 04-05-2010, 06:20 PM
aackshun's Avatar
Sadly, I didn't paint it, car came w/ it painted.
But if you have problems with flaking or the paint coming off then your problem is the prep, not the paint.
You may want to try using a plastic primer after a good sanding and cleaning.
aackshun is offline
Old 04-05-2010, 07:45 PM
Nrw
Nrw's Avatar
Lets see if I remember what I have where. I know I have ~15 in the cluster. One under each window switch. 12 in each map light. 20 in the dome light. 9 in the courtesy lights. Only thing that doesn't have LED's is the radio. All soldered in, nothing pre-made.
Nrw is offline
Old 04-07-2010, 08:50 PM
FYI The blue cluster isn't going in the car with the red CC
Old 04-07-2010, 11:53 PM
aackshun's Avatar
Schmellyfart...
Those are the same LEDs in your gauge cluster right?
The gauge cluster isn't as bright as I'd like, but your CC unit looks to be exactly what I want, not too bright, but enough to see the keys @ night, just perfect! I can't wait till my shipment of LEDs get in from HK, I have some more LED mods planned, hopefully they all work out for the better.
One moar tinggg (no H on perpous), you tried the clock coloring trick? Just red cellophane paper from your local party supply store! One layer turns it white, two turns it red (but too dim to see during the day w/ the lights off!)
aackshun is offline
Old 04-08-2010, 08:14 AM
Which gauge cluster? The red one has 3mm LEDs and athe blue one has 5mm LEDs.
I am very pleased with the way the CC turned out.
No I haven't tried it because I thought you could only do white. Do you think it would be visible in the daytime with the clock always bright mod?
Old 04-08-2010, 12:45 PM
aackshun's Avatar
The red one of course .
I have mine white and I cut the wire, don't really have problems seeing it (unless it's in direct sunlight), but when I tried to make it red, it was barely visible even w/ the illumination wire cut. Thankfully it turned out for the better, I like it white, gives some contrast, I don't want everything RED, RED, RED (Red, red wine makes ya feel so fine!!).
Only thing left to do in my interior LED wise is... DCC, Entry lighting, Dome Light, Map Light and Gauge Cluster!
Speaking of Gauge Clusters... I wish Ilyak would post some pics of his in here...
aackshun is offline
Old 04-08-2010, 01:23 PM
Then yes, I used the same LEDs in the CC as I did in the cluster.
Old 04-08-2010, 09:06 PM
The Golden One
IlyaK's Avatar
Your wish has been granted sir. However, I will have to say that my interior is back to stock. I thought I was going to sell the car (again), but I can never f'in go through with it, so now I'm stuck with another stock interior (for the 2nd time). lol.
Here is some pics of what I had:
  • Switches, climate control, and buttons (hazard, defroster, light) done by BLACKonBLACK98
  • Speedometer done by MOHFPro911
  • LED Bulb for the Shifter Console (sent to me by BLACKonBLACK)
Pictures:
I also have white LED boards in the map, interior lights, and door lights. And the keyring is a blue LED.
IlyaK is offline
Old 04-09-2010, 06:10 AM
pavelsmax's Avatar
Maybe I'll take some updated photos since these are pretty outdated
Reverse indiglo gages with Led needles. (Needles have been red for at least a year now just never updated photos)
1 3mm Led behind each small needle
2 3mm Led behind each large needle
3mm Led for turn signals. (sanded off the green and taped off the arrows from behind)
EDIT: wow just looked at the mileage in this photo. I have just over 229,000 now.....
Climate control and defrost/hazard buttons.
3mm blue Led behind each button to provide evenly lit buttons
3mm red Led behind each indicator behind buttons
3mm blue Led behind "Cold"
3mm red Led behind "Hot"
4 blue 3mm Led's behind fan speed
3mm blue Led in Rear Def with 3mm red in circle indicator light
3mm red Led in Hazard button (blue in this shot but has been changed)
JVC headunit is gone have the Pioneer fh-p8000bt double din now. All blue
Layer of red cellophane on clock (makes it white)
Layer of blue over that (makes it a cyan color that matches the reverse indiglo gages)
3mm blue leds in all window switches
Led's in door handle pockets are gone and i30 chrome door handles are in now
Neons and other rice once on the car all gone thank god.
Also have 5mm blue Led in keyring
3mm Led in dimmer control
3mm Led in Security Light
Two 3mm Led in Cruise Control switch
Two 5mm Led in autotragic shifter
8 bright white superflux leds in Dome light
6 bright white superflux leds in Map light
4 bright white superflux leds in each door light
JBL amp mounted in rear pass through modified with 5 total 5mm blue Leds
I'll try and update with some better pics
pavelsmax is offline
Old 04-09-2010, 06:44 AM
cartman854's Avatar
Thats what im talking about, I want that...... did you add resistors or no? and where did you get those leds?
cartman854 is offline
Old 04-09-2010, 07:40 AM
Nrw
Nrw's Avatar
Pavel, your climate control makes me want to rip mine out and re-do it. :-/
Nrw is offline
Old 04-09-2010, 08:07 AM
pavelsmax's Avatar
I got all of the LED's on ebay. Most i got some time ago from a user named cwithk. They all came with resistors that allow the Leds to be used with 12 volt applications. Each Led has a resistor in all cases except where an led already exsisted (the indicator lights, temp slider, window switches)
Since the climate control is pretty crammed I wired two sets of 3 Leds in series behind the six buttons. I used an online calculator to determine the proper resistor and picked those up from radio shack.
Ha thanks. I've had mine apart too many times to count. Originally I had an all red interior using bulbs and stain glass paint on everything. I ditched that climate control for another that I simply replaced the bulbs with LED's. The light output wasn't even and I decided to fit an LED in for each button. The first try ended up with me frying the climate control. Now on my 3rd climate control I finally got it right.
Old 11-27-2010, 03:00 PM
Black Lion
maxprivate's Avatar
Lexur 1 Led board in map light 97
Anyone try using the Lexur 1 9 led in the map light? I already had one in the rear which works. Finally adding one to the map light and it wont work, I tested it in the door and it works fine. I have 12v at the harness so I know there's no blown fuse. Im beginning to think there is not enough power for the 9 Led to work in the map light. Or the bulb adapter that is used to get power to the Led board is bad. It really hard to test it since its so small.
maxprivate is offline
Old 11-29-2010, 07:53 AM
pavelsmax's Avatar
Did you try plugging the wedge adapter both ways? Unlike an OEM bulb those pre made LED's will only work plugged in one direction.
Old 11-29-2010, 08:19 AM
Black Lion
maxprivate's Avatar
Yup, the wedge adapter is what I used to test it in the door and it worked. I have to use the 1895 adapter for the map light. Either direction I plug it in there doesn't work. It has to be that the adapter is bad. What I'm thinking of doing is cutting the plug off the LED and bring the hot and ground right to where the wires connect to the fixture. If that works then I know the adapter is the problem.
Old 11-29-2010, 11:19 AM
TreizeRXH's Avatar
@ IlyaK, What head unit are you using for your max?
TreizeRXH is offline
Old 11-30-2010, 09:16 AM
wirelessdude04's Avatar
Pavel sickkkk.. PM
wirelessdude04 is offline
Old 11-30-2010, 10:28 AM
maxispeed's Avatar
pavels, how did you get the light by your door handle? that **** is sick
maxispeed is offline
Old 11-30-2010, 07:44 PM
maxed_out_99's Avatar
does anybody know the number of lights in the interior off hand? im starting to get creative here but i only want to pull everything apart once.
maxed_out_99 is offline
Old 12-01-2010, 04:03 AM
Black Lion
maxprivate's Avatar
Good lucks.. most that have done this have done it several times to get it right.
Make sure you get your Leds bright enough so you are happy the light output. This is why its important that people post the MCD'S of the Leds they are using. I have tried up to 15,000 and wasn't happy. FYI
Old 12-01-2010, 06:07 AM
pavelsmax's Avatar
Originally Posted by wirelessdude04
Pavel sickkkk.. PM
Thanks, PM responded
I drilled a 5mm LED into the cup behind the door handle. I wired them to a switch in my center console to turn them on and off. The other option would be to tap into the interior illumination and they would come on with all of your other interior dash lights.
I removed the lights in there when I installed my black leather door panels, felt like it was maybe too much rice for a basically stock car.
Old 12-18-2010, 11:12 PM
defiance's Avatar
Not bad guys not bad at all im liking what im seeing here. I just need to replace the bulbs in my gauge cluster. How many will I need if I wanna replace them all ?
defiance is offline
Old 12-20-2010, 11:21 AM
bpinfiniti's Avatar
Nice I like the look of the blue LEDS.
bpinfiniti is offline
Old 01-10-2011, 02:56 AM
Mistertones's Avatar
Almost done swapping out my interior lights to LEDS. Got the dome light, Map light, doors, Gauges, ACC.
Mistertones is offline
Old 01-11-2011, 01:33 PM
not bad i like
Old 01-11-2011, 05:33 PM
FFMaxima's Avatar
i just order all the leds to do my dash today pic to come soon
FFMaxima is offline
Old 01-25-2011, 11:22 PM
ZeoGox's Avatar
i just finish with the LED mod in my car... now i can say that all the interior lights are LED
tell me what you think about it
go to my page if you want to see them ledxury.blogspot.com
ZeoGox is offline
Old 01-26-2011, 06:42 AM
pavelsmax's Avatar
Wow they look great! I'd like to know more about what you used for the cluster
Old 01-26-2011, 07:36 PM
aackshun's Avatar
+1
It's like the re-incarnation of Ilyak's cluster.
aackshun is offline
Old 01-26-2011, 08:54 PM
defiance's Avatar
Well I replace all my old gauge cluster bulbs with 5 way LEDS from superbriteleds.com and so far I love it. Now I want to LED the rest of
the interior out starting with the climate control cluster!
defiance is offline
Old 01-27-2011, 08:24 AM
Blackwind's Avatar
sooo,what bulbs is everyone using, model numbers? cause i see some good stuff here
Blackwind is offline
Old 01-27-2011, 08:28 AM
tigersharkdude's Avatar
most of the led's in this thread aren't plug and play bulbs, they are soldered LED's
tigersharkdude is offline
Old 01-27-2011, 10:24 AM
Haishun Boi Max's Avatar
Your gauges look great, do you want to do mine?
Haishun Boi Max is offline
Old 01-27-2011, 04:35 PM
Black Lion
maxprivate's Avatar
Im sure those look a lot better in person. Can you post a pic of the exact ones you used?
Old 01-27-2011, 07:40 PM
defiance's Avatar
Yeah guys check this out this is the type of bulbs we need, and you need 5
of them for the gauge cluster.
http://www.superbrightleds.com/cgi-b...%2FWLED-x5.htm
Cool white is 3.94 a piece while red is only 2.99, im thinking about getting Natural white next.
defiance is offline
Old 01-27-2011, 07:53 PM
defiance's Avatar
To the people with questions about install, if you can take the old bulbs out you can put the new ones in ^^ Its just that easy.
They are direct plug and play no resistors needed, or extra wiring.
You can even use the dimmer switch to dim them if they are to bright, which is what
I did when I first bought them but then I got used to them and turned them up to full blast.
Now I want to LED the whole interior out
defiance is offline
Old 01-27-2011, 10:31 PM
black2000maxiSE's Avatar
Just finished my climate control and door switches. Only got a pic of the climate before the battery on my camera died.
black2000maxiSE is offline
Quick Reply: The LED Light Picture Thread -Interior-
