HUGE CAR PROBLEM!!! FAST ANSWER PLZ!
Old 03-20-2010, 11:33 AM
  #41
scmaxima's Avatar
i most definitely will! thanks
btw do u think theyre going to charge me a lot for it?!
scmaxima is offline
Old 03-20-2010, 12:01 PM
  #42
Mr.A32ftw's Avatar
^^I don't know how much they will charge but it will be cheaper than your mechanic
Mr.A32ftw is offline
Old 03-20-2010, 12:08 PM
  #43
scmaxima's Avatar
hmm is it a hard DIY for an entire day
scmaxima is offline
Old 03-20-2010, 01:33 PM
  #44
asand1's Avatar
The black and orange O-rings are not "seals", they are O-ring gaskets. The seals that go bad are the shaft seals, they look like a crank main seal or cam seal and are not replaceable.
If water is coming out the weep hole it means the Shat seals and bearings are toast and the whole pump needs replaced.
Also I did not see mentioned that pouring cold or ambient temp coolant or water into an overheated motor WILL crack a block or head unless your very lucky.
As well, exhaust gasses can enter the cooling system without any other symptoms, some shops have a tool to check the radiator for exhaust using a dye solution.
Good luck, but be prepared to find more problems.
asand1 is offline
Old 03-20-2010, 02:07 PM
  #45
scmaxima's Avatar
hopefully not.. i know that the problem is only the water pump.
and yes the whole pump set is online not just one piece... and the gasket that youre talking about is like 3 bucks
scmaxima is offline
Old 03-20-2010, 02:12 PM
  #46
scmaxima's Avatar
HEY QUICK QUESTION
should i also buy a thermostat assembly like this:
http://cgi.ebay.com/ebaymotors/OEM-N...#ht_1978wt_939
or will the thermostat replacement alone be enough
scmaxima is offline
Old 03-20-2010, 06:33 PM
  #47
Jriv815's Avatar
Originally Posted by vqmaxman
uhhooo.. if your talking about black smoke It's possible that you have damaged your engine because black smoke only can have two symptoms from this, It could be oil burning or the gas is getting burned. Just to make everyone including yourself reliefed about the headgasket issue, try checking the oil dipstick check the color of the oil on the dipstick and make sure it's clear oil color or dark black dirty color, avoid the milky white color on the oil dipstick. I know needing a new engine or tranny really sucks.
Oil being burned will be blue smoke, not black. Look at the smoke from you 2 stroke weed whacker next time your running it. Black smoke is a very very rich Air/Fuel Mixture
Jriv815 is offline
Old 03-20-2010, 07:46 PM
  #48
Hein's Avatar
Originally Posted by scmaxima
HEY QUICK QUESTION
i'm in ny.. and if i knew what i was doing i'd definitely just do it for free but i'm not practicing on anyones car but mine. give it another year and then ask for my help =D
Hein is offline
Old 03-20-2010, 07:47 PM
  #49
Hein's Avatar
^^ that..
buses do it.
Hein is offline
Old 03-20-2010, 08:17 PM
  #50
scmaxima's Avatar
lol you wouldnt know how to do a waterpump replacement =/
scmaxima is offline
Old 03-21-2010, 10:10 AM
  #51
95franklin's Avatar
HEY QUICK QUESTION
You should just buy the whole assembly. The way the Maxima thermostat is, I don't think you can change just the thermostat.
You have all of the knowledge you need to do this, just go out and do it!
95franklin is offline
Old 03-24-2010, 12:52 AM
  #52
michaelp's Avatar
Originally Posted by NJ3ndri
If its a headgasket youll notice smoke at the tail pipe. you need to look under your car to see for a puddle and where its coming from. (i didnt read this entire thread but it sounded like you had a hose leak or radiator cracked)
Holy s**t its endri trying to do the forum thing :P
http://www.courtesyparts.com/21200-t...-p-130206.html
michaelp is offline
Old 03-24-2010, 06:08 AM
  #53
cashoit's Avatar
If you do everythin per the FSM then u shd be fine. Plus u got us for pointers. Jus DONT drop anythin in the timing chain cover and remember that timing chain tensioner is gonna spring out and u WILL need to hold that down somehow.
cashoit is offline
Old 03-24-2010, 06:50 AM
  #54
larso1's Avatar
If you DO drop the spring and piston from the timing chain tensioner into the timing cover, it may not be the end of the world.....if you're lucky. It happened to me when replacing the TC tensioner. I wasn't careful enough about keeping the assembly together after loosening the mounting screws. I was lucky enough to fish out the parts with a mechanic's magnet that has an extension handle. Very lucky.
larso1 is offline
Old 03-24-2010, 07:24 PM
  #55
rnaymik's Avatar
I've been having a leaky radiator lately. i usually have to top it off with about a quarter jug of 50/50 every two to three weeks. Just the other day i found that the leak was coming from the top left corner where the plastic top meets the rest of it. i just ordered a new one and will be installing it as soon as it arrives. its quite a simple job as long as you take your time.
rnaymik is offline
Old 03-24-2010, 07:30 PM
  #56
Grumpy old guy
Nozama's Avatar
This isn't a radiator issue and other than the draining, a radiator is a 20 minute job on our cars.
Nozama is offline
Old 04-20-2010, 07:24 PM
  #57
1992maximase30's Avatar
did the op get his car fixed?
1992maximase30 is offline
Old 04-21-2010, 01:05 PM
  #58
scmaxima's Avatar
why yes i did. It was the water pump and tstat. cost me about 250 bucks but it was well worth it.. There were 3 broken pump fans in my oil so yea 0.o
scmaxima is offline
Old 04-21-2010, 01:13 PM
  #59
mrfliboi's Avatar
i just replaced my radiator and the leak was comming from the top of the radiator.. where the plastic meets the aluminum.. i replaced the radiator and dat was it.. but if ur cap to the back up tank is cracked.. its losing pressure and probably coming from there too..
mrfliboi is offline
Old 04-21-2010, 02:45 PM
  #60
mdliber's Avatar
you say you were on the way back from getting the car painted to the op... lets see some pics
mdliber is offline
Old 04-21-2010, 06:55 PM
  #61
dtortor1's Avatar
i wish i was near nyc! anyone up for a challenge in alabama?
dtortor1 is offline
Old 04-21-2010, 08:17 PM
  #62
scmaxima's Avatar
oh yea! lmao
its all dried up and nice now. ill take pics first thing tomorow! youre gonna see how good it looks =] actually i have some pics from the second day i got it.
quick question though, i need to compound it then polish and wax. where should i be going?
scmaxima is offline
Old 04-21-2010, 08:23 PM
  #63
scmaxima's Avatar
i hate the altezas =/
heres the side, the car wasnt even car washed yet, the day right after the paintjob
sortof dusty hood
the front side. remember not washed yet
So yes thats the "$190" paint job, might not be the best ever but definitely a 100000000x better than the way the car looked before!
now the question is how can i bring life to the car =]
scmaxima is offline
Old 04-23-2010, 05:12 PM
  #64
komik's Avatar
...lately it started finishing all the water tank in 1 day.... and today when i went to get my car painted and came back.. i saw smoke...
Maybe it's just me, but if I had a massive coolant leak, fixing it would take priority over a new paint job. At least you got it fixed before the engine ended up like a certain white GXE I know...
komik is offline
Lakersallday24
06-16-2019 01:35 AM
JMag90
08-25-2015 09:17 AM
MAXSE5SPD
08-23-2015 12:06 PM
kirkhilles
08-08-2015 10:53 AM
yat70458
08-03-2015 01:16 PM
Quick Reply: HUGE CAR PROBLEM!!! FAST ANSWER PLZ!
