OBDII on 95
Old 12-06-2010, 12:13 PM
venturous's Avatar
OBDII on 95
I know that 96 was the first year mandatory on testing, but for some reason I thought someone had mentioned that the 95 Maxima also could be tested. I have a 95 and a 96 and have routinely used a tester on the 96, but have never really looked at any way to do anything on the 95.
Anyone have any info on this?
Thanks,
Randy
venturous is offline
Old 12-06-2010, 12:15 PM
kevinoseguera99's Avatar
yea some 95s had it, all the 95 maximas had it, the port is on the passenger side of the center console, everything scans the same.
kevinoseguera99 is offline
Old 12-07-2010, 06:42 AM
venturous's Avatar
Thank you very much Kevin. I will take a look at it. I don't think it has a check engine light, or it is burned out.RandyA
Old 12-07-2010, 08:15 AM
cartman854's Avatar
Passenger side of the center under kick plate. Pop off the two things and test.
cartman854 is offline
Old 12-07-2010, 09:03 AM
asand1's Avatar
ALL 4 gen maximas are OBD. Nissan started OBDII in the maxima two years before it was mandated by the government. Dont let any shops or mechanics tell you otherwise, they just dont better.
asand1 is offline
Old 12-08-2010, 09:22 AM
53jimc's Avatar
As has been stated on this forum many times, the knock sensor could be setting a code, but the CEL will not come on. It's worth checking codes just to see if the KS is operational.
53jimc is offline
Old 12-08-2010, 09:26 AM
still check anyway, yea. my car has the engine light one, problem is the bulb is blown out, so you would never know lol
Old 12-08-2010, 02:28 PM
Trini Boom's Avatar
This is usually the case or either when you purchase the car from someone, the remove the bulb...like my cousin did when he called for help when his car was stalling...told him get the codes read and there were 7 codes but no light. Removed the cluster and no bulb...
People need to know when the key is turned to on, they should see the light before starting. If not, the person is hiding something..
Trini Boom is offline
lummyrob
09-02-2015 12:31 AM
JClaw
05-04-2005 08:09 PM
Pyrophilus
01-31-2005 08:26 PM
woosh
05-22-2002 11:42 AM
Quick Reply: OBDII on 95
