Wiring issues...
Old 02-27-2010, 09:53 PM
Bakermax's Avatar
Wiring issues...
So I took my 98GLE to a stereo shop to install a bypass for my Alpine in dash DVD player. They got it to work, but the next day I drove to work, I noticed that the gauge lights are no longer lit up. I checked all the fuses, they are fine. Could the stereo being installed have interfered with the gauge lights? I'm not sure how it could happen, but the gauges don't light up anymore. All the other lights in the cluster work, the CES, low fuel, E brake, all that stuff lights up and the gauges work, they just aren't lighting up.
Any suggestions?
Bakermax is offline
Old 02-27-2010, 09:59 PM
nismomaxgtr18's Avatar
You made sure that you didn't set the dimmer switch to off right?
nismomaxgtr18 is offline
Old 02-28-2010, 10:55 PM
maxi_pad's Avatar
ur dimmer switch lol
maxi_pad is offline
Old 03-02-2010, 05:00 AM
slow_yota's Avatar
theres a monkey in your closet ?
slow_yota is offline
Old 03-02-2010, 07:20 AM
cashoit's Avatar
had the same problem when i installed my radio.
Ur Illumination fuse is blown in the fuse box. 7.5 Amp fuse i think. Its caused by improper radio grounding and the dimmer (orange) wire not being taped off
Make sure all wires behind the radio are taped off with electrical tape so they dont accidently touch a metal surface and create an unintentional circuit.
Second, there are two ground wires to the car behind the radio. I cant remeber which one to use but there is a combo that will work for proper grounding. I think avoid amplifier ground.
Buy a couple 7.5A fuses and try different combos till the guauges stay lit and radio and everything else works.
FYI, Best Buy dont know SH*T lol!!! Better off doin it urself.
cashoit is offline
Old 03-02-2010, 08:06 AM
wirelessdude04's Avatar
yea, best buy has the know it all's lol
wirelessdude04 is offline
trsandrew
04-08-2016 06:45 PM
doctorpullit
03-29-2016 11:08 AM
trsandrew
10-25-2015 02:47 PM
Kyle Lee Cleveland
09-28-2015 09:03 AM
Quick Reply: Wiring issues...
