How do I remove double side 3M tape
Old 02-04-2010, 03:37 PM
_buddha's Avatar
The previous owner of my maxima put in these gay woodgrain interior trim from eBay:
http://cgi.ebay.ca/NISSAN-MAXIMA-199...item2c52efc503
well it looked fine in te beginning except now they are starting to tear and look ugly due to sun exposure, how do I get rid of this crap? Anyone remove 3M tape before from the interior? Will it leave a mark or should I just buy new interior?
_buddha is offline
Old 02-04-2010, 03:46 PM
CRK
CRK's Avatar
a hair dryer/heat gun, plastic putty knife/credit card and some wd-40 are your friends.... go SLOWLY!! it will come off.. if you hurry your going to scratch something..
CRK is offline
Old 02-04-2010, 03:59 PM
_buddha's Avatar
that sounds like a huge hassle, might just get some new parts off another car. Btw how hard is it to remove and install these ?
_buddha is offline
Old 02-04-2010, 04:29 PM
Mistertones's Avatar
Ronsonol Lighter Fluid works well for removing stuff like that.
Mistertones is offline
Old 02-04-2010, 06:54 PM
Sold
JSMax's Avatar
for removing the adhesive stuff left after you peel off the actual tape... yes... the lighter fluid works just fine.
also, you could try goo gone. you won't have to worry about staining the interior.
JSMax is offline
Old 02-04-2010, 07:36 PM
Papa Yams's Avatar
removing glue residue
Another thing you can use to remove a lot of gooey stuff is Murphy's Oil Soap. This stuff is made from a vegetable product and won't stain, mark or deteriorate plastic or vinyl.
Added bonus - the Murphy's Oil Soap KICKS *** on tree sap. I had a bad case of pine tree sap in my wife's Mercedes. Tried all kinds of stuff and then used the Murphy's - gone in no time! Doesn't remove the wax from the paint either.
Papa Yams is offline
Old 02-05-2010, 02:58 PM
smai555's Avatar
or you can polish them... use the a headlight polishing kit or check the detailing section of the forum
smai555 is offline
Old 02-06-2010, 05:49 PM
_buddha's Avatar
polish what? if ur talking bout the dash kit that im trying to remove, polishing it will do nothing
_buddha is offline
Old 02-06-2010, 06:39 PM
smai555's Avatar
you can polish out the fading and light scratches but if its chipping and cracked then yea replace it or remove it i have never remove but im guessing its just plastic pieces that are taped on and as everyone above me said use a heat gun and or goo gone/ rubbing alcohol
i guess i was just trying to give another option
or after removing it and it does leave a mark you can polish them out
smai555 is offline
Old 02-06-2010, 06:52 PM
808s96SE's Avatar
there are all kinds of adhesive removers out there. http://www.google.com/products?hl=en...ed=0CDkQrQQwAg
808s96SE is offline
Old 02-06-2010, 07:08 PM
bigpopaj369's Avatar
whatever u do use, keep in mind a little heat will go along way
bigpopaj369 is offline
Old 02-06-2010, 07:15 PM
maxfever1987's Avatar
a blow dryer is your best bet, pry it off slowly and you will see how eell the blow dryer works
maxfever1987 is offline
Old 02-11-2010, 12:43 PM
saylee's Avatar
at work i use pro-sol to take off gunk like that, like really bad build up... I shaved my emblems in the back and had the left over residue from the molding but when i used the pro-sol, it took it off really easy.. you can find it at the store, the one i use is called PRO-SOL Bug/Tar remover.. its non-flammable also...
saylee is offline
The Frye
09-02-2021 11:03 AM
03-12-2020 12:06 AM
Dennis Twohy
10-01-2015 06:01 PM
nissan99
09-11-2015 03:52 AM
Colossus
09-09-2015 05:46 AM
Quick Reply: How do I remove double side 3M tape
