Changing Spark Plugs
Old 02-10-2010, 07:55 AM
cashoit's Avatar
So Im reading the maintenance section of the FSM, MA-16 to be exact. And i read something that disturbed me:
The FSM says, "checking and adjusting plug gap for platinum tipped is not required between change intervals" ????????
Does that make any sense whatsoever? The HAYNES definitely says to check and gap according to spec.
WHy the heck would the FSM say gaping a new spark plug is not required. I think u definitely want to check each plug is gapped correctly.
cashoit is offline
Old 02-10-2010, 07:59 AM
Rider's Avatar
Some plugs are factory gapped. As a precaution though I always check the gap but I've never had to adjust the gap.
Rider is offline
Old 02-10-2010, 08:04 AM
aackshun's Avatar
+1
aackshun is offline
Old 02-10-2010, 08:10 AM
67whitegoat's Avatar
Always check the gap. You can't hurt anything by double checking.
67whitegoat is offline
Old 02-10-2010, 08:30 AM
jkahng's Avatar
ngk platinums' platinum tips are laser welded.
you will damage / separate the tip if you try to gap them
bosch platinums have a very thin platinum core surrounded by a ceramic housing. you will damage the ceramic if you try to gap them.
(you shouldn't be using bosch plugs for maximas anyway)
if you drop ngk platinums, you should not use that plug. just get another one.
ngk coppers you can gap all night long.
jkahng is offline
Old 02-10-2010, 08:44 AM
cashoit's Avatar
I kno the last time i changed the plugs they werent NGK Platinums and i had to gap them. And it worked fine. I would still check the gap even if they were NGKs.
cashoit is offline
Old 02-10-2010, 08:47 AM
wirelessdude04's Avatar
yea better safe then sorry with gapping
wirelessdude04 is offline
Old 02-18-2010, 02:52 PM
DIAMONDS98SE's Avatar
would new spark plugs possibly help my hesitation during wot? i also get widely varying mpg. it ranges from 19 to 31. just curious.
DIAMONDS98SE is offline
Old 02-18-2010, 02:57 PM
xkazik's Avatar
they might if your spark plugs haven't been replaced in a long time. you can check your fuel filter, see how old it is .
xkazik is offline
Old 02-18-2010, 03:30 PM
adamsanders's Avatar
It sounds to me that they mean that you don't have to check the gap, say every 1000 miles, even if you change them every 20,000. Like, you only gap them when you are installing them, and then you throw them away when you install they next set. You never have to pull the plugs, re-gap, and then re-install them. If that makes sense lol
adamsanders is offline
Old 02-18-2010, 03:34 PM
bigpopaj369's Avatar
i did plugs a few months back used NGK V-power plugs $1.99 @ autozone, they are not bad at all, definitely double check the gapping
bigpopaj369 is offline
Old 02-18-2010, 05:02 PM
ThreePointO's Avatar
thats what i was thinking too
ThreePointO is offline
Old 02-28-2010, 06:12 PM
mkzg's Avatar
I never gap plugs and never had a problem? on the maxima it should be done every 60k right? if they are true platinums.
mkzg is offline
Old 03-02-2010, 05:12 AM
hangout's Avatar
I still have some factory NGK for the 92 Maxima SE left over,,
do you think it might be fit on my 97 Maxima GLE now?
please give me an idea..
hangout is offline
Old 03-02-2010, 05:52 AM
The Golden One
IlyaK's Avatar
Hangout. NGK Coppers are like $2/each. Just go buy 6. Why would you wanna use plugs from a 92 on a 97? You can't afford that? Perhaps owning a car isn't in your best interest.
IlyaK is offline
Old 03-02-2010, 06:49 AM
cashoit's Avatar
+1
Go new with plugs
cashoit is offline
Old 03-02-2010, 03:29 PM
bkbajan's Avatar
wht about denso double platinums?
bkbajan is offline
Old 03-02-2010, 05:33 PM
defiance's Avatar
Denso's are for toyota engines like the 3vz and the 1mzfe.
defiance is offline
Old 03-02-2010, 06:08 PM
Mistertones's Avatar
Don't mean to thread jack, but I could never get to the spark plug against the firewall driver side. Any tips on pulling out the coil pack? There is some metal thing blocking it.
Mistertones is offline
Old 03-02-2010, 07:03 PM
bkbajan's Avatar
so these are a no-go?
bkbajan is offline
Old 03-02-2010, 07:43 PM
JwaxMax99's Avatar
Myself and others here have used the Denso Iridium IK16. They work flawlessly.
JwaxMax99 is offline
Old 03-02-2010, 07:58 PM
defiance's Avatar
I'm sure the denso plugs are great for Nissan engines like the VQ and they prolly work much better then Bosch. But I cant vouch for them because I never used them.
In fact my old 87 Camry 3sfe is using NJK V Powers right now so yeah I've always been an NGK kind a guy ^^
defiance is offline
Old 03-03-2010, 05:21 AM
cashoit's Avatar
Kinda hard to say without pics....but when i did my plugs firewall side, i do remember having to unbolt a bracket somewhere in that area. jus be careful not to break anything.
Dont worry bout the jack..happens all the time
cashoit is offline
Old 03-03-2010, 05:50 AM
96i30azn's Avatar
"between change intervals" refers to the time between when you've installed the new plug to when you have to get rid of it for another.
what it's basically saying is that the plug will be good for the 60k it's rated at w/o you messing with it in between.
Actually, I just checked on NGK site and it appears they use the same plugs.
96i30azn is offline
Old 03-03-2010, 08:04 PM
bkbajan's Avatar
changed all 6 today,was surprised to find the car had denso's in it already...
i put the double platinums i bought in..no more hesitation..
fuel filter will be changed 2moro
bkbajan is offline
Old 03-03-2010, 09:26 PM
stobelma's Avatar
I changed mine the other day with the platinum NGKs. Took about an hour to do. The number 3 cylinder was a little tricky but if you remove the sensor just above it. Its no problem. There were bosch plugs in there before for 70,000 miles. All the plugs were still in ok condition.
stobelma is offline
Old 03-04-2010, 05:04 AM
dragonboyokada's Avatar
+1 :-)
dragonboyokada is offline
mvm062
11-30-2020 09:00 AM
knight_yyz
11-06-2015 02:34 PM
ag90fox
09-09-2015 12:22 PM
sdotcarter
09-02-2015 09:53 PM
maximusrising
09-02-2015 09:55 AM
Quick Reply: Changing Spark Plugs
