will it work
Old 12-25-2012, 08:55 AM
greenspeed's Avatar
will it work
I'm getting ready to swap a 95 max motor into my 97 because of low miles. Are there any parts that I need to swap over or change. I no longer have the original motor, but will all sensors and vacuum lines work in order with the 97 harness. Thank for all info...
greenspeed is offline
Old 12-28-2012, 10:41 AM
Blown
cardana24's Avatar
The 97 may have more emissions stuff mounted on top of the intake manifold but other than that they will be the same. All of the plugs are the same. If you do have more emissions stuff that the 97 ecu is looking for you could always swap in a 95 ecu and be done with it (the 95 ecu would not be looking for the extra stuff that the 97 may have).
Change your mind on the 3.5?
cardana24 is offline
Old 12-28-2012, 10:55 AM
nsnrider's Avatar
what did you do with your original motor? I have done many swaps but I don't throw away the old motor until I get the replacement in and working properly. You will need the emisions parts to make everything work properly as mentioned above.
nsnrider is offline
Old 12-28-2012, 11:00 AM
Amerikaner83's Avatar
97 should be exactly the same...the extra emissions came on the 99 cali specs
Amerikaner83 is offline
Old 12-29-2012, 04:01 PM
maxfever1987's Avatar
Ur wrong here,
A stock 95 motor is diff. When compared to a stock 97 motor emission wise
95 was the one with least emissions, 96-98 added few extra emission components such purge valve, purge solenoid, map sensor, than again in 99 added more emission components such as per-cats,4 o2 sensors instead of 3, swirl valve etc
maxfever1987 is offline
Old 12-29-2012, 09:06 PM
the 4 o2 sensors was for CALI spec only though. All 4th gens had two precats in the stock y pipe iirc.
I'll take your word that the stock 97 motor is slightly different than the stock 95 motor.
mvm062
11-30-2020 09:00 AM
kmitchel
10-30-2015 10:12 AM
Maxima30
09-07-2015 06:13 PM
iflexsteel
09-02-2015 08:04 AM
Hailstatejig
09-02-2015 06:52 AM
Quick Reply: will it work
