Rear Brake Stuck
Rear Brake Stuck
First of all, I replaced both rear calipers, rotors, and pads last year (2008) around Christmas time, and every time I park my car, I use the e-brake, it's just become a habit....
The problem started yesterday. I used the e-brake and I heard something, I'm not sure what, and after that, the e-brake was very easy to pull at the beginning and as I lifted it, it became harder to pull. As I drove home the car felt sluggish (like the brakes were dragging.) When i got out, it was clear that they were. I could smell it and feel it when I put my hand near the brakes.
The driver-rear caliper appears to be stuck.
I searched, and came to the conclusion that something happened with the cable so I removed the wheel and disabled the e-brake cable from the caliper. Put the wheel back on, drove in reverse for ~75 ft (i read to reset the ebrake), but still no good. I checked the brake fluid, it was below the cold min level, filled it up, tried reverse again, still nothing...
Is there anything else I can try short of removing/replacing the caliper?
Any info would be great.
Thanks in advanced.
Thanks in advanced.
Looks like someones gotta replace his rear calipers =[ sorry bud...
but before you do so; check to make sure the line isnt magically seized; and if your really feeling lucky try to turn in the piston..
I just replaced them both a little over a year ago though. What are the chances of it only lasting that long when the originals lasted about 10 years?
Spent a couple hours checking out the rear caliper tonight...
I found the problem... but it's not totally fixed.
The parking brake lever (part #4) had somehow been turn CCW when i pulled the ebrake (the sound I mentioned that I had hear when I pulled it yesterday.) I moved it back to the correct position and the wheel, i mean rotor, spun very easily (it wouldn't move prior.) I put everything back the way it was supposed to and took it for a drive. Everything seemed good... until i tried to use the ebrake again. I heard the sound again, and i could tell the brake was dragging again. I fixed the lever again but just left the e-brake cable off to avoid this problem again. Part number 6 in the picture seemed loose though, and i feel that's the root of the problem.
I would prefer to have the ebrake working, but I'll have to deal without it for the time being. If anyone has any idea how to repair this, short of replacing the whole caliper, I would love to hear it.
Thanks for the input guys.
read this thread
http://forums.maxima.org/4th-generat...e-e-brake.html
if it is the caliper pin/slider you can pull it out and re-lube it
also check to make sure the the cable your pulling off slides freely back and fourth
there is a spring that pulls the cable back to release the caliper from the rotor its like 4 bucks from the dealer (and thats the only place i found it) give that a try if you want
Happened to me again today. Im thinking the cold weather has something to do with it as well because when i came home from school yesterday, it was fine again and the ebrake worked. Its been 4 degrees the past two days tho so its too cold to even go out and look at it right now :-(
otherwise the stealer... i mean dealer
i bought a used set from someone parting out a car i added lube and im crossing my fingers
yea jus had that happen 2 me. check the link that smai555 put up...that was my thread. i just kept playing with the lever over & over and moved the car back and forth and it came loose. ill fix mine wen its warm cuz my max is a 5spd n i need my ebrake.
Same thing happened to me today
My drivers side rear brake just did same thing. Drove it last night and it was fine. Drove it around neighborhood today and came back and it was smoking. If it is caliper, which I hope it is not, I don't have to replace both sides do I?
No need to replace whole caliper. You have a seized caliper. Either the piston is seized or the guide pin. You can always rebuild your caliper with new seals for SOO much less than the price of new caliper.
They are design failures. I have changed out at least 4 or 5 sets from different Nissan cars with these kinds of calipers. All the pistons were seized with rust on the sides. You can sand down the piston to remove the rust, but the metal is already pitted and it will most likely rust again.
Good luck getting the piston out of the caliper if the piston is seized. Which is 99% of the time on these type of calipers.
However, the piston metal is always porous. If the seal is not damaged, what would allow the moisture to enter the chamber? The break fluid wouldn't make it rust. Now don't get me wrong, I'm just debating out loud. I'm not trying to offend anyone and by no means am I questioning your knowledge. I'm just going based on my experience. Here is the thread from my rebuild:
http://forums.bimmerforums.com/forum....php?t=1283237
But if you say it's a design flaw, then be it. I have 98 SE calipers for sale if anyone wants them
I can't argue with you as I simply don't know if it is possible or not. I was simply giving my point of view.
Generally all the rubber seals fail too, allowing moisture to enter and rust to form. All moisture needs is a small pinhole.
The rebuild on your BMW calipers is much easier because the pistons are not the types that you need to "turn" to get out. Unfortunately, the ones on the Nissan are the ones that need turning and those won't come out easily.
I'll do a pictorial on the next set I do.
Not really. If it were it would weep brake fluid rather than let water in.
Rebuilding calipers is a calculated risk on all vehicles with some mileage. The rust makes rebuilding them a mess and IMO not worth the effort. I buy reman calipers from Napa - reasonable price and good quality.
Dave
Dave
Huttig2009
09-25-2015 03:31 PM
RealityCheck
08-05-2015 06:18 AM
