Radiator drain plug is stripped/seized
Old 01-29-2003, 03:39 PM
jam4me's Avatar
When trying to do a coolant flush/refill, I ended up overtightening my radiator drain plug. When I attempted to re-open the radiator plug, it stripped. Instead of stopping, I continued to try to get the d*mn thing to open and stripped it further.
Now, I don't know what to do? Does anybody here have any suggestion on how to get a stripped/seized radiator drain plug out?? I still have those 4 notches on the outer rim of the drain plug which might be of use if I could find a tool or instrument that I could use to remove the thing. I have already tried a power drill --it didn't work.
jam4me is offline
Old 01-29-2003, 09:17 PM
humberto_i30's Avatar
Repair kit
radiators.com or radiator.com sells a cheap kit to fix your problem, just get a look at the site and check for yourself.
humberto_i30 is offline
Old 01-29-2003, 09:29 PM
Xmax's Avatar
You really don't have to buy a new radiator, but if your experienced, I suggest that you retap the thread on the radiator (rethread) with a tapping tool which you probably could go to your local hardware store and find it. When you have done retapping the drain hole, you probably need to get a new size plug which proably be the same size as the tapping tool you used. When looking for the right tapping tool you prolly don't have to go big, but just maybe a 1/16th of a inch bigger. But be aware, the way you tap the drain hold could cause a leak when putting in the new drain plug. Good luck Oh almost forgot, just cut what is sticking out now, with maybe a dremel, and drill a hole thru the rest.
Xmax is offline
Old 01-30-2003, 05:04 AM
cbr2's Avatar
Re: Radiator drain plug is stripped/seized
NO-NO-NO... Don't worry about the stupid plug if you did noit cause it to leak leave it be. Just remove the big hose that goes to the bottom of the radiator instead. It will do the same thing. Don't waste your time or money doing anything else.
cbr2 is offline
Old 01-30-2003, 07:35 PM
jam4me's Avatar
Ok
Thanks folks, for the suggestions!
Now, I have a question: Where is the big radiator hose at? How do I get to it? Is it difficult to unhook and drain the radiator from there? Does anyone have a "How to"? Or how about a picture?
I bought another radiator drain plug today from Advance Auto for like a dollar. So, if that darn plug pops off, I have a replacement. If not, I guess I'll be using the hoses from now on...
jam4me is offline
Old 03-16-2024, 03:32 PM
cangaffer's Avatar
stripped rad plug.
Hi...just had the exact same issue today. Flushed my 2002 nissan pathfinder...took the drain plug out, drained a few times, then put plug back in, refilled with distilled water and flushing solution....next morning when I went to empty the rad again the drain plug would not come out. Needless to say I was pissed...however, I figured it out as written above that the lower rad hose was just as good a drain point as the plug. So don't panic. When the car is cooled off take the lower hose off and flush to your hearts content, reattach the lower rad hose, fill rad and reservoir with correct coolant and check for air bubbles. Oh and by the way I wouldn't bother screwing with the plug again unless it is leaking....Cheers from Canada.
cangaffer is offline
hcarter1112
42
07-18-2022 03:35 PM
Miket2006
03-01-2021 03:55 AM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
magiconthetire
10-26-2015 09:03 PM
Quick Reply: Radiator drain plug is stripped/seized
