Help locating the EGR Solenoid valve.
Old 12-31-2009, 04:10 PM
Justaguy's Avatar
Okay. I searched and searched thru this forum and most of the time when I find the thread that will reveal where the EGR Solenoid valve is located, the webpage is not found or the photo that hosts the pics is gone. I've read thru the stickies and it doesn't mention where this thing is located. I looked near the dip stick and I don't see any green plug.
One post says that he doesn't have it on his car and the plug is brown (????).
I'm looking for this right?
[IMG][/IMG]
This is the car.. a 1997 Maxima. ..If someone can pinpoint me to the right area..please.
[IMG][/IMG]
While I'm at it, I'm looking for the EGR-BPT valve as well...
Thanks Guys!!
Justaguy is offline
Old 12-31-2009, 04:22 PM
ATTappman's Avatar
You can just barely see it in the second picture you posted. See the accelerator and cruise control cables? Look just below them and a little to the left, and you'll see the fuel pressure regulator, a brass-colored round part with a black vacuum hose coming out of the bottom. From there, look just a little down and a little left, and you see a splotch of green. That's your EGRC solenoid valve. It's just to the right of the "valley" underneath the intake manifold.
The EGR-BPT valve is well concealed. It's approximately below and to the right of the throttle body (if you're standing on the driver's side of the car), covered up by hoses and other stuff.
ATTappman is offline
Old 12-31-2009, 04:27 PM
ATTappman's Avatar
Turns out I had a picture:
It's the green part in the center of the picture.
Old 12-31-2009, 09:37 PM
Justaguy's Avatar
Great!! I see it now!!! Thanks a million!..and Happy new year!
I removed my throttle/Iac as well...what does a EGR-BPT look like? I think it's the one next to the EGR tube and has 2 screws on top of it and it's round and thin?
Justaguy is offline
Old 12-31-2009, 09:46 PM
Justaguy's Avatar
Is this it? (the egr bpt)..the one with the two screws
Thanks again....with my throttle and IACV out, the Solenoid valve should be easy to replace.
[IMG][/IMG]
Justaguy is offline
Old 01-01-2010, 05:55 AM
ATTappman's Avatar
Yes, that's it.
Old 01-01-2010, 08:23 AM
Justaguy's Avatar
How do you remove it? (the egrc-BPT). I can take out the two screws but what about that little square metal piece on top?
Also, what is under it? Is it just a hose to unclamp?
(Sorry I'm not near my car right now and I'm planning on doing this early tomorrow morning.
Thanks!
Justaguy is offline
Old 01-12-2011, 02:23 PM
triax37's Avatar
Just wanted to follow-up on this - were you able to remove the valve? Also, does anyone know the part numbers for the hoses in the pictures? Thanks!
triax37 is offline
Old 02-15-2011, 05:36 PM
goldmax's Avatar
Question...I'm hearing what sounds like an exhaust noise coming from that area, mostly when I rev the motor and let it come back to idle...could it possibly be the EGR or EGR-BPT? The EGR valve seems to be holding vacuum. I haven't checked the EGR-BPT since i didn't know what it was until after I had put the air cleaner back on. Can either valve make strange noises like that if they fail? Would seem to make some sense, but I've never heard of the situation.
goldmax is offline
Old 02-15-2011, 06:01 PM
wirelessdude04's Avatar
good info
wirelessdude04 is offline
Old 02-17-2011, 05:14 PM
goldmax's Avatar
Anyone????
goldmax is offline
Old 02-17-2011, 06:24 PM
foamerdave's Avatar
If the EGR tube has a crack or any of the EGR gaskets are bad then yes.
foamerdave is offline
Old 02-17-2011, 06:56 PM
goldmax's Avatar
I can't feel any pulsing, but that area is tight, so I need to look at those components a little closer.
goldmax is offline
Old 02-18-2011, 01:05 PM
Justaguy's Avatar
Sorry I'm a little late on the reply...Yes I did get it off, it was a real pain. The screw is at the bottom and you need a twisted wrench to get it. It sits on a bracket and I had to bend it a little in order to get my hand under that screw.
I don't have the part numbers because I didn't replace the hoses. I inspected them and they were fine.
Justaguy is offline
Old 08-13-2011, 02:52 PM
The original VQ...
maxspeed96CT's Avatar
Can someone help me find the egr tube/connections in a 01 maxima.
I dont see any pipes coming off the rear manifold like the 95-99 maximas.
And Im getting a slight leak (tisk tisk tisk sound) when i rev and drop back down to idle , plus im getting alittle oder in the car with the a/c on.
I cant find any leaks in my exhaust, tripple checked everything.
Were do I look as fasr as egr connections and tubes.
Please help guys.
maxspeed96CT is offline
my03maxima
04-29-2020 12:48 AM
doctorpullit
03-29-2016 11:08 AM
RealityCheck
10-02-2015 06:34 PM
fx4five
10-01-2015 04:58 AM
Quick Reply: Help locating the EGR Solenoid valve.
