Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 11-29-2009, 03:49 PM   #1
Points: 7,185, Level: 56
Points: 7,185, Level: 56 Points: 7,185, Level: 56 Points: 7,185, Level: 56
Activity: 8.9%
Activity: 8.9% Activity: 8.9% Activity: 8.9%
John Holley
Baffle Plate Replacement
Due to a flood 4 years ago both rear baffle plates are rusted away and broken in several spots. I replaced the calipers, mounts, rotors, and pads back then. The hubs look fine. While I replace the pads again next week I might as well replace those baffle plates.
After I slide the rotors off, do I just need to remove the locknut and hub bearing to slide the baffle plate off the splindle?
jholley is offline   Reply With Quote
Old 11-30-2009, 04:58 AM   #2
Points: 35,333, Level: 100
Points: 35,333, Level: 100 Points: 35,333, Level: 100 Points: 35,333, Level: 100
Activity: 11.4%
Activity: 11.4% Activity: 11.4% Activity: 11.4%
Send a message via AIM to njmaxseltd
Baffle plate?
Are you refering to the splash guards in back of the rotors?
Yes they rust up pretty good over time.
They are held on by a few small bolts. Remove the rotor and you'll see the bolts.
njmaxseltd is offline   Reply With Quote
Old 11-30-2009, 06:16 AM   #3
Activity: 8.9%
John Holley
Quote:
Originally Posted by njmaxseltd View Post
Baffle plate?
Yes the inside splash guards are what the service manuals label as the baffle plates.
Since there is no Wheel Bearing Assembly on the rear axle is it safe just to remount the Wheel Hub back on the splindle? If I did this on the front axle it would definitely need a realignment.
Old 11-30-2009, 06:41 AM   #4
Activity: 11.4%
I don't think you need to remove the hubs or bearings to replace the baffle.
Just remove the rotor to expose the bolts that hold it in place.
Old 11-30-2009, 07:02 AM   #5
Activity: 8.9%
John Holley
I inspected the rear brakes yesterday and the wheel hub bearing assembly needs to removed in order to remove the baffle plates.
When I remount the wheel hub bearing assembly will I need to use a dial guage to realign the ball bearings?
Old 11-30-2009, 12:52 PM   #6
4th Gen Parts King
Maxima_Joe's Avatar
Points: 22,152, Level: 92
Points: 22,152, Level: 92 Points: 22,152, Level: 92 Points: 22,152, Level: 92
Activity: 11.9%
Activity: 11.9% Activity: 11.9% Activity: 11.9%
You need to remove the hubs to get the shields/baffles off in one piece or new ones back on. I would just use an air chisel or even some tip snips and cut them off and not bother putting new ones on.
Maxima_Joe is offline   Reply With Quote
Old 11-30-2009, 01:48 PM   #7
I'm nutty for Nissans
JSutter's Avatar
Points: 25,399, Level: 96
Points: 25,399, Level: 96 Points: 25,399, Level: 96 Points: 25,399, Level: 96
Activity: 5.1%
Activity: 5.1% Activity: 5.1% Activity: 5.1%
Send a message via AIM to JSutter
i havent had ones for years, no worries.
__________________
-Jon
07 Frontier SE CC 4x4 ... Daily driver.
98 Maxima SE 00VI VLSD ... 14.9 @ 95 (I/Y/B). Never ending project.
94 Sentra SE-R ... 1/8: 8.2 @ 94, 2.1 60' 356whp/322wtq. After 3 passes, on hiatus.
91 Sentra SE-R ... 1/8: 8.6@ 86, 1/4: 13.1 @ 110, 2.2 60' 250whp. After 7 passes, totalled.
03 Altima 3.5 SE ... Hers.
JSutter is offline   Reply With Quote
Old 12-02-2009, 05:45 AM   #8
Activity: 8.9%
John Holley
I just cut off the left rear baffle plate. The right one was just rusted so I left that one on. I was worried if left rear caliper I replaced would get damaged easily without that plate sheilding it. I replaced them with OEMs so they were not cheap.
I replaced those rear semi-metallic pads with Hawk HPS ceramic pads so they'll last longer this time.
After finishing the rear brakes I inspected the front ones. The front calipers and mounts are orignal. The bottom pins on both mounts were rusted shut. After using strong force to remove them I cleaned and lubricated them.
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
