Windshield washer fluid doesn't spray
Old 11-13-2009, 04:22 PM
burgundyblues66's Avatar
It just stopped working one day, any ideas as to why.
The reservoir is full but nothing comes out when i push the spray button on the right side of the steering.
Thanks!
burgundyblues66 is offline
Old 11-13-2009, 06:13 PM
trooplewis's Avatar
Can you hear a "whine" from the WW pump when you use it? If yes, your sprayers are clogged and need to be cleaned out, usually you can do it with the sharp tip of a safety pin.
If you don't hear the pump motor making noise, then you need to buy a new pump. They are about 20 bucks at Rock Auto, I have one on my workbench right now that I need to install in my 96 Max.
trooplewis is offline
Old 11-13-2009, 06:17 PM
bigpopaj369's Avatar
thats basically it man what trooplewis said
bigpopaj369 is offline
Old 11-13-2009, 06:58 PM
bryan163's Avatar
This happened to my neighbors maxima. His pump was running, but nothing was making it to the nozzle. It turned out that the hoses and nozzles were completely clogged with bits of paper from the inside of a washer fluid jug lid. You know, that little paper disc that falls out of the lid sometimes. At least that's what I think it was.
I was able use compressed air to blow out the hoses, but I had to replace the nozzles because I couldnt get all of the paper slurry out.
bryan163 is offline
Old 11-13-2009, 09:10 PM
trooplewis's Avatar
Never heard of that happenng, but I've often wondered if any of it gets in oil pans or radiators or even gas tanks with the foil crap they seal bottles with.
Usually if its plugged, it's the nozzles on top of the hood that have excess wax in them from the last time you polished your hood.
Old 11-14-2009, 08:58 AM
well, theres no sound at all when i push the spray button.
also, there are 4 sprayer nozzles (2 small ones for each side) and not one of them works, i dont think all 4 can get clogged at once. is there a motor or something that is responsible for the spray pump?
Old 11-14-2009, 09:02 AM
sorry, i didnt see you post trooplewis, rockauto looks good for that part.
which part number is it? it gives me 4 different pumps for my car.
also, where is the thing located? is it safe to say its a problem with the pump if it doesnt make a sound??
Old 11-14-2009, 01:42 PM
HandsonMaxima.'s Avatar
make sure your wires are good,
on mine i had to re pin the plug because the wires inside the plug actually were rotted and broke
HandsonMaxima. is offline
Old 11-14-2009, 06:25 PM
Grumpy old guy
Nozama's Avatar
Since you can't hear it it's the plug or the pump but why wouldn't all four nozzles get plugged at once?
One hose feeds four nozzles and the pump will push fluid to the place with least resistance which is always going to be the nozzles that aren't plugged right up until they plug too.
Nozama is offline
Old 11-14-2009, 06:34 PM
BrettLinton7's Avatar
I love rockauto... If it's for sure your pump and there's no fuse in the system, definitely hit them up.
BrettLinton7 is offline
Old 11-14-2009, 06:52 PM
where is the pump?
Old 11-14-2009, 09:24 PM
trooplewis's Avatar
I'll change out mine in the morning and give you more info, but I understand that the pump has to be accessed from below the car with the cover panel removed near the oil filter. The pump shoud be just downstream from the washer fluid container.
Old 11-14-2009, 09:40 PM
nitromax's Avatar
it's on the bottom of the reservoir, behind the r/f inner fender cover. check your fuses first.
nitromax is offline
Old 11-15-2009, 04:25 PM
Jriv815's Avatar
I would definately check the fuse of the system first. Dont automatically assume that it is a mechanical failure. With the cars that are on the road there is more to worry about electronically than mechanically. Check the fuse, then check the plug at the pump. Check to see if there is power coming to the pump from the battery when the switch is actuated. And...if there is power and ground at the pump then using a 9 volt battery and 2 little wires, find the power and ground pins at the pump and attach the wires. If the pump doesnt do anything...then you have just found the problem.
Jriv815 is offline
Old 11-15-2009, 08:15 PM
trooplewis's Avatar
OK, I installed a new washer pump today, It is a bit of a messy job, but not difficult; takes about 15 minutes.
I posted a mini now-to thread here:
http://forums.maxima.org/4th-generat...ml#post7297242
IN my case it was definitely the pump that was shot. A soon as I put the new one in, everything worked OK again.
Old 11-15-2009, 08:27 PM
_buddha's Avatar
damn that sucks
_buddha is offline
Old 07-11-2012, 01:16 AM
maxima209's Avatar
my washer "t" broke and i was wondering where i could find one?
maxima209 is offline
Old 07-11-2012, 01:30 AM
2brosgixxer's Avatar
Any parts store should have something that'll work. Or just pick one off a wreck at a junkyard.
2brosgixxer is offline
Old 07-22-2014, 03:48 PM
nissan99's Avatar
were is the fuse located ?under the dash ?what is it named after on 99 max...
nissan99 is offline
captchaos
03-15-2016 12:18 PM
02PearlSE
02-01-2016 12:37 AM
fastcarny
10-12-2015 07:06 AM
bumpypickle
09-19-2015 01:07 AM
Maxxx10
09-13-2015 03:16 PM
Quick Reply: Windshield washer fluid doesn't spray
