Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-06-2009, 05:15 PM   #1
Send a message via AIM to sergofast
Could we add this question to the stickies please
What is the Biggest brake upgrade that you can fit under a stock 97-99 SE rim?
The J30 i know will fit (the rotor diameter is the same only thicker, you just have to play around with clearancing the factory torque member or use the j30 loaded caliper and shave about 3mm off the rotor). What about a 5.0 or 5.5? I have read that they will fit on a 16" rim....but not specifically the 97 SE 16" rim.
sorry if im beating a dead horse here....
sergofast is offline   Reply With Quote
Old 11-06-2009, 05:33 PM   #2
Nrw
Send a message via AIM to Nrw
I'm pretty sure the 5.5 will fit under the stock se 16's. Since I saw a 5.5 the other day with 4th gen se 16's on it.
__________________
Nrw is offline   Reply With Quote
Old 11-06-2009, 06:09 PM   #3
The Dirty Pearl
pmohr's Avatar
Quote:
You'd be surprised, the stock 5.5 brakes will fit under a 15" wheel. Yes, the wheels still spun freely.
Too bad I never got a clearance picture, but it was certainly close. Here's the closest thing I have:
Click the pics for full res.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 11-06-2009, 06:17 PM   #4
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
you do not have to shave anything off the diameter of the J30 rotor to use a J30 caliper.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 11-07-2009, 12:43 AM   #5
so if these will fit under the stock rims what is better the j30 with thicker rotors and 2 pistons or the 5.5 with a larger diameter single piston caliper?
A bit of clearancing and grinding on the stock 4th gen torque member to fit the j30 or enlarging the bolt holes for the 5.5?
opinions?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
