Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-03-2009, 09:55 PM   #1
Bad battery or bad alternator?
So on my way out i was driving and i noticed my dash lights slowy get dimmer, then pulling into gym it slowly turned off and car wasnt able to start....no icons on dash such as battery or anything and lights still worked but car wouldnt start...changed alternator about 2 years ago or less, and got a new battery...used another cars battery to get it home and she worked fine...could it be the battery or the alternator that is on its way out? any info would be greatly appreciated...Thanks!
KDog125 is offline   Reply With Quote
Old 11-04-2009, 05:23 PM   #2
its gotta be the alternator since the car died.. take a volt meter and jump start the car.. put it on the battery.. see if you get 14 volts..
then as the car is running remove the negative cable and measure again (positive to ground obviously) .. if the car dies the alternator is the problem
dont have the battery unhooked with the car running for longer than like a minute
__________________
f550maranello2 is offline   Reply With Quote
Old 11-04-2009, 05:30 PM   #3
321VQ35MAX's Avatar
Correct. Sounds like alternator. 9 times out of 10 battery will not cause car to shut off, just not to start.
__________________
321VQ35MAX - 03 Black 6spd T.E - Injen CAI-Tein S Tech Springs - Tokico Illuminas - Clear Markers- ES Shifter bushings - ES subframe bushings - ES mount inserts
Best 1/4 -14.501 @ 95.99 mph 2.20 60 ft....
321VQ35MAX is offline   Reply With Quote
Old 11-04-2009, 07:06 PM   #4
I bet its the alternator. My car did exactly the same when my alternator died last year.
The headlights were very dim, the airbag light came on, and then it slowly died. And then wouldnt start.
It started a few minutes later, but my tach and speedometer did not work. Was trying to drive it home, and it again slowly sputtered and died. Battery was fine, but alternator was dead.
Maximamisfire is offline   Reply With Quote
Old 11-18-2009, 09:54 AM   #5
My Max 99 takes longer to start.
How would I know if it's starter or battery/alternator?
Thank you.
romicva is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
