Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-03-2009, 05:58 PM   #1
Send a message via AIM to black_maxed95
Water pump O-rings
I ordered new orings for my water pump cause its leaking coolant. Ive done this fix before on my old maxima so I know what to expect. This time my question is I just ordered the two O-rings from courtesyparts and got the part numbers:
21049-31U04 -- [21010JA] SEAL O-RING
21049-31U03 -- [21010J] SEAL O-RING
All this looks fine except they are both black! I know the one oring is suppose to be orange. Did Nissan recently change how they made these orings? Does it matter? I just dont want to do all this work and not have the right oring.
Last time I ordered these orings it was from everythingnissan and I got one of each color.
__________________
I like to "do it myself"
5MT SE 96er:
MEVI + NWP Spacers, Full Exhaust, Flywheel, lotsa more:
MOD LIST
Quote:
Originally Posted by ironwork View Post
i am knew to this forum am i am amazed at how costructive your arguments are. no flameing and well thought posts.
black_maxed95 is offline   Reply With Quote
Old 11-03-2009, 06:58 PM   #2
The Dirty Pearl
pmohr's Avatar
It's an updated design, been around for a fair amount of time now.
One should be black, the other black with a white dot.
I can't find where I got the information, I believe it was a TSB but can't seem to locate it now. Here's a pic from the A34 FSM, same thing:
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 11-03-2009, 07:06 PM   #3
Thanks alot pmohr. Exactly what I wanted to hear. I looked at them closer and I see the white dot on one. Didnt know about this before.
__________________
5MT SE 96er:
MOD LIST
Old 11-03-2009, 07:17 PM   #4
Also when I posted this thread, I knew you were probably going to be the one to answer me
__________________
5MT SE 96er:
MOD LIST
Old 11-03-2009, 07:25 PM   #5
Send a message via AIM to njmaxseltd
I sure do hope your replacing the pump and not just the o-rings.
I've never heard of the 0-rings leaking, the pump usually leaks at the shaft seal.
At that point, it's toast.
njmaxseltd is offline   Reply With Quote
Old 11-03-2009, 07:28 PM   #6
Ive heard and researched its the opposite...that its the orings that go bad and cause the leak. Last time I did it I did everything but this time I was just planning on doing the O-rings.
__________________
5MT SE 96er:
MOD LIST
Old 11-03-2009, 07:37 PM   #7
Gut it like a fish
accordingtou's Avatar
Its usually the o rings but I have had some leak from the shaft or weap hole too
__________________
Stock & performance parts F/S@ PANTRY sale.lol Philly Pa
accordingtou is offline   Reply With Quote
Old 11-03-2009, 07:39 PM   #8
I should probably just do the pump too...I dont want to have to do it again since I know what a b**** it is.
Since I am doing this job this weekend (must do before temp gets below freezing, only water in car now) Im not going to wait for another courtesyparts order, and Im not going to pay $100 plus from the local dealer so I will pick this up.
http://www.oreillyauto.com/site/c/de...PartType=C0331
__________________
5MT SE 96er:
MOD LIST
Old 11-03-2009, 09:54 PM   #9
ColombianMax's Avatar
Send a message via AIM to ColombianMax
Hey I might be in Indianford, WI which is like 30 min from you in case you need a hand..
__________________
SHIFT_I cant it's Automatic!!
1993 Maxima GXE Super White, Ebay FSTB, 97-99 SE Rims, KYB GR2s, BlehmCo Lower Tiebar, BlehmCo parallel link kit, RSTB, BlehmCo swaybar links,Rear Addco swaybar, z31 rear disc upgrade, Assurance TripleTreds.
1995 Maxima GXE-5 Dark Blue Pearl , 00-01 SE RIMs, I30 leather w/rear headrests, No rubber- all ES Poly in front end suspension, Pioneer InDash Navi, Kzoosho LED tails and FX35 HID retrofit
ColombianMax is offline   Reply With Quote
Old 11-03-2009, 09:59 PM   #10
Quote:
I probably wont need the help since Ive done this before but if you want to stop by cause your bored or whatever, PM me friday and Ill give you the details. Ill most likely be working on it saturday.
__________________
5MT SE 96er:
MOD LIST
Old 11-03-2009, 11:39 PM   #11
That works, I'll let you know if anything
__________________
Old 11-04-2009, 11:30 AM   #12
Great info to know! I'm concerned this is something i need to do soon at 190K mi.s ? How do you know it's leaking? Mine always seems like it needs a little coolant topped off every now and then. What should I be looking for since it's buried under the timing chain cover? I agree with njmaxseltd I would absolutely swap pump and rings together!
__________________
97 Super Black Max...
maxirob is offline   Reply With Quote
Old 11-04-2009, 11:50 AM   #13
Its generally your waterpump (or O-rings) leaking if you have a little puddle of coolant on the ground under your crank pulley or near that area. Dont be confused with a puddle from your AC condensor though if you recently had that running, but coolant should be obvious as it has color.
How often do you need to top it off and by how much? This summer I was putting about a gallon and a half of water every month, now I have to do it twice a week cause it got worse. This is why I am fixing it before winter because putting $20 worth of coolant in a week would be expensive.
__________________
5MT SE 96er:
MOD LIST
Old 11-04-2009, 11:53 AM   #14
I just did this the other day for a friend and he had a bosch pump. I put on the o-rings and one was snug while the other was loose. I took them both off and traded places and then both were snug. They had no white dots.
__________________
SHIFT_NFS
Quickywd01 is offline   Reply With Quote
Old 11-04-2009, 11:55 AM   #15
Your pump was probably from an auto store that came with generic o-rings. The ones Im talking about in the first post are about the OEM Nissan ones.
__________________
5MT SE 96er:
MOD LIST
Old 11-05-2009, 08:07 PM   #16
replaced the water pump today. I did the worst of worst and accidently dropped the tensioner piston and spring in the timing chaing cover...1 hour of fishing it out with a magnet on the end of a wire and i got it out. That was a relief. After that it went smoothly and the water pump no longer leaks. However now I found a new leak. My radiator is cracked.
__________________
5MT SE 96er:
MOD LIST
Old 11-05-2009, 09:50 PM   #17
that was the scariest thing for me. hoping that the piston of the tensioner doesn't fall in. but thank god my repair went smoothly
__________________
1996 Nissan 240SX sold
1995 BMW 740 IL totaled
1995 Nissan Maxima SE sold
2005 Acura RSX type-s crashed
1995 Nissan 240SX blown engine
1997 Nissan Maxima GXE Current
and im just 18
whiteSE is offline   Reply With Quote
Old 11-06-2009, 08:04 AM   #18
Ya this time was I was sorta rushing it a little bit since its the second time Ive done it and wasnt being careful. I took one of the tensioner bolts out thinking the other would still hold it but the tensioner rotated and shot the piston down.
__________________
5MT SE 96er:
MOD LIST
Old 11-06-2009, 09:22 AM   #19
This is good info. I need to to the waterpump on my 99 again. I made the mistake of not using an OEM waterpump or O-ring kit the first time...and now it's leaking again.
Funny thing is that it ONLY leaks when it's cold out...
__________________
TLMNICK is offline   Reply With Quote
Old 11-06-2009, 09:25 AM   #20
Quote:
Thats when they always start for me too, I think its probably because in the cold the o-rings must shrink just enough to let the coolant by.
__________________
5MT SE 96er:
MOD LIST
Old 11-06-2009, 09:34 AM   #21
The Dirty Pearl
pmohr's Avatar
Same for me, replaced it about 4 years ago and it just started leaking.
Hopefully this time it isn't a 3 day job like it was back then
__________________
Old 11-06-2009, 09:37 AM   #22
Took me 8 hours the first time I did this with no mistakes, only 5 hours yesterday and that was with dropping the stuff in the timing cover. If I had to do it again and didnt drop anything, I could probably do it in 3 or 4 hours.
__________________
5MT SE 96er:
MOD LIST
Old 11-06-2009, 02:59 PM   #23
The last time I did it took me about 4 hours to do, and I got a huge cut on my thumb from compressing the piston inside the tensioner.....I took the pin out while I had the tensioner sitting out of the motor. When it came time to put it back in, I didn't use a vice to hold the tensioner.....bad idea.
__________________
Old 11-06-2009, 04:49 PM   #24
When I put the tensioner back in, I had the piston compressed and used a safety pin to hold it in. That worked really well. Once I had the tensioner bolted in and the chain tightened back up, then I just pulled the safety pin out.
__________________
5MT SE 96er:
MOD LIST
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
