Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-30-2009, 02:15 PM   #1
Send a message via Yahoo to JDM_Maxima
maxima cutting off
what a headache!
96 max with over 240k
i just found out today that one of the many problems my maxima has now includes a electrical one. turns out that some where between the fuel pump and the ecu there is a drop in voltage, as to why sometimes when coming to idle at a stop the car will cut off. what ive been doing is just when im coming to a stop, rev the engine a few times and that keeps it going. however the rpm sometimes will drop so low that the oil pressure light will come on.
has anyone experience this before or have any suggestions on what could be the problem?
__________________
I Like Rice But Not Enough To Drive It
JDM_Maxima is offline   Reply With Quote
Old 10-30-2009, 02:26 PM   #2
Send a message via AIM to urmab Send a message via MSN to urmab
How do you know that the voltage drops between the ecu and the fuel pump. To me is sounds like there is something else. Any CEL? if so what you have if none its possible that you might have a bad coil or maybe a faulty maf or wiring that goes to the maf. Also check your iacv make sure its clean, some times it might cause the car to idle low. Also clean your TB if it has a lot of built up it might close to tight and that might effect your idle as well.
__________________
Ultimate mod 1.6 L IVtec LOL
Turbo project soon to be completed
urmab is offline   Reply With Quote
Old 10-30-2009, 07:03 PM   #3
Check the Talon forums for a how-to on fuel pump rewiring. Easy to do. Commonly done on talons to keep the fuel pressure constant while under boost. Pump gets wired directly from battery for constant voltage.
Not sure it'll work for a Max but might be worth looking into.
brucerap is offline   Reply With Quote
Old 10-30-2009, 07:31 PM   #4
The Dirty Pearl
pmohr's Avatar
Exactly how much are we talking? Is the fuel pump only seeing ~9.5V? If so, that's perfectly normal under most conditions.
If it's lower than that, have you tested the FPCM?
What exactly makes you assume that it's the fuel pump that's causing your issues? What is your fuel pressure at when it tries to die?
Have you tested the MAF, IACV, and TPS? Cleaned TB/IACV? Have you done any sort of diagnostics to fix this problem? If so, what?
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 10-30-2009, 08:54 PM   #5
that sounds like a pretty good idea. you have a link to the talon forums or i can just google it?
__________________
Old 10-30-2009, 08:56 PM   #6
The Dirty Pearl
pmohr's Avatar
Quote:
Would've taken less time to google it then ask.
http://tinyurl.com/ykurstt
Personally, I would actually do some diagnostics before bypassing a potentially perfectly functioning setup.
__________________
Old 10-30-2009, 08:56 PM   #7
Quote:
well thats what the mechanic at the shop i took my car to told me was happening. since the car was there already there to get one issue fixed with one diagnostic price they had to do another one to atleast find out that info. after that the bill was getting too high for me and i told him maybe some other time ill get that further looked into.
__________________
Old 10-30-2009, 09:00 PM   #8
very good questions and points, ill have to get a multimeter and check them out. i was lead to the issue of the voltage dropping from the diagnostic that the mechanic ran on it
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
